I'm implementing an HID class device and have based my program on the HID USB program supplied by Keil. I'm new to USB but am a fairly experienced programmer otherwise.
I have got a basic program working fine bit with single byte input and output reports. I've tested the functionality using a client called SimpleHIDWrite.exe
I need to expand both in and out reports to 8 bytes each to communicate with the host. Has anybody successfully modified this example program or does anyone have any advice on how to do it properly?
My guess is that I need to edit the report descriptor and also set up the inreport and outreport as arrays. Is there anything I need to watch out for?
My target is the LPC2141.
Any advice or information would be much appreciated!
Thanks, Gareth.
Sorry - should have mentioned that I'm not using the basic example, I'm using the RTX USB HID example supplied with RL-ARM.
The report byte size (count) on the report descriptor is defined by these #defines Increase these figures.
C:\Keil\ARM\Boards\Keil\MCB2140\RL\USB\RTX_HID\usbdesc.c #define HID_INPUT_REPORT_BYTES 1 /* size of report in Bytes */ #define HID_OUTPUT_REPORT_BYTES 1 /* size of report in Bytes */ #define HID_FEATURE_REPORT_BYTES 1 /* size of report in Bytes */
The example declares just interrupt IN endpoint. Increase wMaxPacketSize, so that it fits to the report byte size (up to 64 bytes)
C:\Keil\ARM\Boards\Keil\MCB2140\RL\USB\RTX_HID\usbdesc.c /* Endpoint, HID Interrupt In */ USB_ENDPOINT_DESC_SIZE, /* bLength */ USB_ENDPOINT_DESCRIPTOR_TYPE, /* bDescriptorType */ USB_ENDPOINT_IN(1), /* bEndpointAddress */ USB_ENDPOINT_TYPE_INTERRUPT, /* bmAttributes */ WBVAL(0x0004), /* wMaxPacketSize */ // <--------- 0x20, /* 32ms */ /* bInterval */
The buffers for the reports are defined in demo.c Increase the buffer size. GetInReport() and SetOutReport() are revised, so that they fill/retrieve increased report size
C:\Keil\ARM\Boards\Keil\MCB2140\RL\USB\RTX_HID\demo.c U8 InReport; /* HID Input Report */ <---- make these variable to array U8 OutReport; /* HID Out Report */ void GetInReport (void) { ... } void SetOutReport (void) { ... }
When you use control transfer for input/output/feature report, ie. Get_Report/Set_Report requests, HID_GetReport() / HID_SetReport() handlers are called on the stack. Modify these handlers.
C:\Keil\ARM\Boards\Keil\MCB2140\RL\USB\RTX_HID\hiduser.c BOOL HID_GetReport (void) { /* ReportID = SetupPacket.wValue.WB.L; */ switch (SetupPacket.wValue.WB.H) { case HID_REPORT_INPUT: GetInReport(); EP0Buf[0] = InReport; // <------ memcpy( EP0Buf, InReport, sizeof(InReport) ); break; case HID_REPORT_OUTPUT: return (__FALSE); /* Not Supported */ case HID_REPORT_FEATURE: /* EP0Buf[] = ...; */ /* break; */ return (__FALSE); /* Not Supported */ } return (__TRUE); } BOOL HID_SetReport (void) { /* ReportID = SetupPacket.wValue.WB.L; */ switch (SetupPacket.wValue.WB.H) { case HID_REPORT_INPUT: return (__FALSE); /* Not Supported */ case HID_REPORT_OUTPUT: OutReport = EP0Buf[0]; // <------ memcpy( OutReport, EP0Buf, sizeof(OutReport) ); SetOutReport(); break; case HID_REPORT_FEATURE: return (__FALSE); /* Not Supported */ } return (__TRUE); }
The size of EP0Buf array is USB_MAX_PACKET0. Increase it, too (8, 16, 32, or 64 bytes are allowed)
C:\Keil\ARM\Boards\Keil\MCB2140\RL\USB\RTX_HID\usbcfg.h #define USB_MAX_PACKET0 8
Tsuneo
Here is modification of the KEIL example. In this snippet, we implement, - Interrupt OUT EP - Feature report handling - Loopback of an output report to an input report from interrupt OUT EP to interrupt IN EP - Loopback of a feature report from Set_Report( feature ) to Get_Report( feature )
Jan Axelson's generic_hid_cs is good for the PC test application of this mods (Thanks to Jan! ) "The HID Page" http://www.lvr.com/hidpage.htm generic_hid_cs www.lvr.com/.../generic_hid_cs_46.zip
The snippet below shows just mods on the firmware code.
usbcfg.h #define USB_MAX_PACKET0 64
usbdesc.c #include "hiduser.h" // moved to hiduser.h //#define HID_INPUT_REPORT_BYTES 1 /* size of report in Bytes */ //#define HID_OUTPUT_REPORT_BYTES 1 /* size of report in Bytes */ //#define HID_FEATURE_REPORT_BYTES 1 /* size of report in Bytes */ /* USB Configuration Descriptor */ /* All Descriptors (Configuration, Interface, Endpoint, Class, Vendor) */ const U8 USB_ConfigDescriptor[] = { /* Configuration 1 */ USB_CONFIGUARTION_DESC_SIZE, /* bLength */ USB_CONFIGURATION_DESCRIPTOR_TYPE, /* bDescriptorType */ WBVAL( /* wTotalLength */ USB_CONFIGUARTION_DESC_SIZE + USB_INTERFACE_DESC_SIZE + HID_DESC_SIZE + USB_ENDPOINT_DESC_SIZE + // <-------- USB_ENDPOINT_DESC_SIZE // <-------- increased by OUT EP ), 0x01, /* bNumInterfaces */ 0x01, /* bConfigurationValue: 0x01 is used to select this configuration */ 0x00, /* iConfiguration: no string to describe this configuration */ USB_CONFIG_BUS_POWERED /*|*/ /* bmAttributes */ /*USB_CONFIG_REMOTE_WAKEUP*/, USB_CONFIG_POWER_MA(100), /* bMaxPower, device power consumption is 100 mA */ /* Interface 0, Alternate Setting 0, HID Class */ USB_INTERFACE_DESC_SIZE, /* bLength */ USB_INTERFACE_DESCRIPTOR_TYPE, /* bDescriptorType */ 0x00, /* bInterfaceNumber */ 0x00, /* bAlternateSetting */ 0x02, /* bNumEndpoints */ // <-------- increased to 2 EP USB_DEVICE_CLASS_HUMAN_INTERFACE, /* bInterfaceClass */ HID_SUBCLASS_NONE, /* bInterfaceSubClass */ HID_PROTOCOL_NONE, /* bInterfaceProtocol */ 0x04, /* iInterface */ /* HID Class Descriptor */ /* HID_DESC_OFFSET = 0x0012 */ HID_DESC_SIZE, /* bLength */ HID_HID_DESCRIPTOR_TYPE, /* bDescriptorType */ WBVAL(0x0100), /* 1.00 */ /* bcdHID */ 0x00, /* bCountryCode */ 0x01, /* bNumDescriptors */ HID_REPORT_DESCRIPTOR_TYPE, /* bDescriptorType */ WBVAL(HID_REPORT_DESC_SIZE), /* wDescriptorLength */ /* Endpoint, HID Interrupt In */ USB_ENDPOINT_DESC_SIZE, /* bLength */ USB_ENDPOINT_DESCRIPTOR_TYPE, /* bDescriptorType */ USB_ENDPOINT_IN(1), /* bEndpointAddress */ USB_ENDPOINT_TYPE_INTERRUPT, /* bmAttributes */ WBVAL(0x0040), /* wMaxPacketSize */ // <-------- increased to 64 bytes 0x01, /* 1ms */ /* bInterval */ // <-------- changed to 1ms /* Endpoint, HID Interrupt Out */ // <-------- added OUT EP USB_ENDPOINT_DESC_SIZE, /* bLength */ USB_ENDPOINT_DESCRIPTOR_TYPE, /* bDescriptorType */ USB_ENDPOINT_OUT(1), /* bEndpointAddress */ USB_ENDPOINT_TYPE_INTERRUPT, /* bmAttributes */ WBVAL(0x0040), /* wMaxPacketSize */ 0x01, /* 1ms */ /* bInterval */ /* Terminator */ 0 /* bLength */ };
usbuser.c #include <string.h> static OS_SEM USB_IN_EP1_Semaphore; // semaphore for IN EP1 /* * USB Endpoint 1 Task * Handles USB Endpoint 1 Events */ #if (USB_EP_EVENT & (1 << 1)) __task void USB_EndPoint1 (void) { U16 evt; U32 report_size; for (;;) { os_evt_wait_or(0xFFFF, 0xFFFF); /* Wait for an Event */ evt = os_evt_get(); /* Get Event Flags */ if (evt & USB_EVT_OUT) { // OUT EP1 interrupt comes report_size = USB_ReadEP( HID_EP_OUT, OutReport ); // read out the output report // usually, your firmware parse the output report, here // in this snippet, just copy output report to input one directly, for loopback memcpy( InReport, OutReport, report_size ); // send an input report to IN EP os_sem_wait( USB_IN_EP1_Semaphore, 0xffff ); // wait until IN EP is available USB_WriteEP( HID_EP_IN, InReport, HID_INPUT_REPORT_BYTES ); // pass it to the endpoint } if (evt & USB_EVT_IN) { // IN EP1 interrupt comes os_sem_send( USB_IN_EP1_Semaphore ); // IN EP1 is free /* GetInReport(); USB_WriteEP(HID_EP_IN, &InReport, sizeof(InReport)); */ } } } #endif /* * USB Core Task * Handles USB Core Events */ __task void USB_Core (void) { #if (USB_CONFIGURE_EVENT || USB_INTERFACE_EVENT || USB_FEATURE_EVENT) U16 evt; #endif for (;;) { os_evt_wait_or(0xFFFF, 0xFFFF); /* Wait for an Event */ #if (USB_CONFIGURE_EVENT || USB_INTERFACE_EVENT || USB_FEATURE_EVENT) evt = os_evt_get(); /* Get Event Flags */ #endif #if USB_CONFIGURE_EVENT if (evt & USB_EVT_SET_CFG) { if (USB_Configuration) { /* Check if USB is configured */ os_sem_init( USB_IN_EP1_Semaphore, 1 ); // IN EP1 is available now /* GetInReport(); USB_WriteEP(HID_EP_IN, &InReport, sizeof(InReport)); */ } } #endif #if USB_INTERFACE_EVENT if (evt & USB_EVT_SET_IF) { } #endif #if USB_FEATURE_EVENT if (evt & USB_EVT_SET_FEATURE) { } if (evt & USB_EVT_CLR_FEATURE) { } #endif } }
hiduser.h /* HID report size (count) */ #define HID_INPUT_REPORT_BYTES 64 /* size of report in Bytes */ #define HID_OUTPUT_REPORT_BYTES 64 /* size of report in Bytes */ #define HID_FEATURE_REPORT_BYTES 64 /* size of report in Bytes */ /* HID In/Out Endpoint Address */ #define HID_EP_OUT 0x01 #define HID_EP_IN 0x81
hiduser.c #include <string.h> BOOL HID_GetReport (void) { /* ReportID = SetupPacket.wValue.WB.L; */ switch (SetupPacket.wValue.WB.H) { case HID_REPORT_INPUT: GetInReport(); // EP0Buf[0] = InReport; memcpy( EP0Buf, InReport, SetupPacket.wLength ); break; case HID_REPORT_OUTPUT: return (__FALSE); /* Not Supported */ case HID_REPORT_FEATURE: GetFeatureReport(); memcpy( EP0Buf, FeatureReport, SetupPacket.wLength ); break; } return (__TRUE); } BOOL HID_SetReport (void) { /* ReportID = SetupPacket.wValue.WB.L; */ switch (SetupPacket.wValue.WB.H) { case HID_REPORT_INPUT: return (__FALSE); /* Not Supported */ case HID_REPORT_OUTPUT: // OutReport = EP0Buf[0]; memcpy( OutReport, EP0Buf, SetupPacket.wLength ); SetOutReport(); break; case HID_REPORT_FEATURE: memcpy( FeatureReport, EP0Buf, SetupPacket.wLength ); SetFeatureReport(); break; } return (__TRUE); }
demo.h /* HID Demo Variables */ extern U8 InReport[ HID_INPUT_REPORT_BYTES ]; extern U8 OutReport[ HID_OUTPUT_REPORT_BYTES ]; extern U8 FeatureReport[ HID_FEATURE_REPORT_BYTES ]; /* HID Demo Functions */ extern void GetInReport (void); extern void SetOutReport (void); extern void GetFeatureReport (void); extern void SetFeatureReport (void);
demo.c #include "hiduser.h" #include "demo.h" U8 InReport[ HID_INPUT_REPORT_BYTES ]; /* HID Input Report */ U8 OutReport[ HID_OUTPUT_REPORT_BYTES ]; /* HID Out Report */ U8 FeatureReport[ HID_FEATURE_REPORT_BYTES ]; /* HID Feature Report */ /*------------------------------------------------------------------------------ Get HID Input Report -> InReport *------------------------------------------------------------------------------*/ void GetInReport (void) { // this function is called just when Get_Report( input ) request comes // fill InReport[] with an input report, here // if ((FIO2PIN & PB_INT0) == 0) { /* Check if PBINT is pressed */ // InReport = 0x01; // } else { // InReport = 0x00; // } } /*------------------------------------------------------------------------------ Set HID Output Report <- OutReport *------------------------------------------------------------------------------*/ void SetOutReport (void) { // this function is called just when Set_Report( output ) request comes // At the entry of this function, OutReport[] holds an output report from the host // IOPIN1 = (IOPIN1 & ~LED_MSK) | (OutReport << 16); } /*------------------------------------------------------------------------------ Get HID Feature Report -> FeatureReport *------------------------------------------------------------------------------*/ void GetFeatureReport (void) { // this function is called just when Get_Report( feature ) request comes // fill FeatureReport[] with an input report, here } /*------------------------------------------------------------------------------ Set HID Feature Report <- FeatureReport *------------------------------------------------------------------------------*/ void SetFeatureReport (void) { // this function is called just when Set_Report( feature ) request comes // At the entry of this function, FeatureReport[] holds an feature report from the host }
This makes sense and I suspected that the streaming input reports were just the way the example was set up.
Can I check my understanding of your latest post? ...
In order to put out InReports as and when required I need to set up an IN EP (interrupt) on Endpoint 1 - with an event handler like the one in the lower code sample? So I need to use the descriptor to describe this EP.
I just need to properly understand what mechanism prompts the system to generate the interrupt which causes the report to be transferred to the host. I suppose what I'm asking is how the GetInReport function in the main program is related to the mechanism within the USB engine which then transmits the report via the EP to the host?
Just for example ... an important variable in my system changes (similar to the mouse moving) and I want to send that new value to the host. When this happens I can detect it and update the InReport array within GetInReport. What is the part which knows that this must be transmitted NOW?
Thanks for your ongoing assistance - I am making fast progress and I feel that my understanding is moving forward all the time!
Gareth
Good day Tsuneo and all
quite interesting to find this thread right on top ... :D
Here is the situation: I already changed HID reports successfully on ARM7/2366. (to 60) This was almost straight forward and works fine. So I am not new to all the stuff (But of course still light year's away from other 'T' - user's expertise)
Now I wanted to do the same with the latest USB HID sample provided for MCB1700 (so this included a switch to CORTEX)
I did all the stuff above, and in principal, it works too, but only for the Report Sizes 1,2,3 and 4. (and yes, I enlarged EP0Buf to 64 (resp MAX_PACKET_SIZE0)
whenever I got to reports > 4, it stops working
is there somewhere a known maximum or bug ?
MANY MANY thanks in advance for any illumination ULI
An interrupt IN EP is mandatory for every HID device implementation. Input reports are sent over this EP.
As USB is host centric, devices don't have any method to send data actively. Just when an IN transaction comes from host, the device gets chance to send data. This is the reason why PC HID class driver polls the interrupt IN EP repeatedly by IN transactions.
The sequence to send an input report is as follows, 1) First, firmware fills the IN endpoint buffer with an input report using USB_WriteEP() call 2) The USB engine waits for an IN transaction from host 3) When an IN transaction comes, the engine sends the data on the endpoint buffer 4) When the IN transaction completes, the engine generates a hardware interrupt on this EP 5) RL-ARM library interprets the hardware interrupt to an event
Please note, the EP hardware interrupt occurs just after the transaction finishes successfully (data is sent). The hardware interrupt doesn't occur when the IN endpoint buffer is empty on transaction, and the engine returns NAK. ie. the IN EP hardware interrupt means the timing when the endpoint buffer becomes empty right now.
Then, when are we allowed to put an input report to the EP buffer? The answer is any time, unless the EP is occupied by the last report. In above snippet, the IN EP event is used just to release the semaphore, to notify that the IN EP is available now. Also, your firmware can put an input report everywhere on your code, where required.
Hi ULI,
Sound like the limit of 4 bytes comes from wMaxPacketSize of the interrupt IN endpoint, doesn't it?
C:\Keil\ARM\Boards\Keil\MCB1700\USBHID\usbdesc.c const U8 USB_ConfigDescriptor[] = { ... ... /* Endpoint, HID Interrupt In */ USB_ENDPOINT_DESC_SIZE, /* bLength */ USB_ENDPOINT_DESCRIPTOR_TYPE, /* bDescriptorType */ USB_ENDPOINT_IN(1), /* bEndpointAddress */ USB_ENDPOINT_TYPE_INTERRUPT, /* bmAttributes */ WBVAL(0x0004), /* wMaxPacketSize */ <--------- 0x0040 ie. 64 bytes 0x20, /* 32ms */ /* bInterval */
grrrrr............................ I was close to losing consciousness upon reading this..
THANK YOU TSUNEO ONCE MORE !!!!!!!!!!!!! I had marked all the spots of modification then with the ARM 7 stuff, oviously all except one ...
in general, what is your opinion regarding these samples in quality? from my viewpoint, they could a lot better regarding modularization and ease of use... eg my current (solved) problem: it would have been a lot easier to have just U8 InReport[REPORT_SIZE] and only one single point for definition and modification
or, eg if looking at the string descriptors ...
how to handle a "reallife" serial number properly ? this sample won't work if it is stored in an EEProm
what do you think of my idea to solve this ? keep all strings in ordinary const char and, upon startup (before USBInit !!) go through them and expand them to wide strings in the given string descriptor structure. Upon extraction, I can easily fill in my real serial number from elsewhere. does this sound OK ?
again: a big thanx
ULI
PS to Garrett: apologies for stumbling in
Not so bad, but not so good. I recommend the programmers of KEIL stack to read as many stack code from others. Most of USB MCU manufacturers release their own USB stack. Also, examine the interfaces of commercial USB stacks. These materials will give many suggestion on the organization of the stack.
It's OK. One step advance, this string expansion process is directly integrated in Get_Descriptor( string ) handler, so that the string expansion goes on demand. And then, you can save RAM space for the expanded strings.
If this stack would have an extra hook for SETUP handler, we could modify the behavior of the stack without changing the stack code at all. This kind of hook is seen on other stacks, like Microchip, ST micro, EZUSB, etc.
thank you once more!
Strings on demand sounds smart.
My problem is that a REAL understanding from bottom to top is still not existent, despite your posts and Axelson's books. Nowadays, all the sales guys say: get this library, get this component, stick it together, add some glue code and then lets sell it. No spare time to go into detail, no way to become a real expert, especially if in the meantime (last time I was at USB in detail was March or so) so many other topics were hot and needed immediate attention.
regarding the KEIL code, I think its limitations show up once you want to transform it into "real code". from my point of view, it should be easy to separate the sources and have the option to treat them in a "library style" (eg separate folders, maybe even in compiled form) this is not possible here as they have mixed up everything. (eg the core includes demo.h, and all resides in one folder) First thing for me to do after I got it to basically communicate will be "cleaning up and separating" (and hoping it will not be broken afterwards)
btw, for these tests I always use the HID Exerciser. (cool tool)
<<<Sometimes>>> (not sure about the circumstances and not regularly) upon arrival of one of my (Keil driven) devices, the detection (readout of strings) fails and the exerciser only lists VID+PID in hex. Any idea what this might be? This seems never to happen with other devices.
Another point I always have to add:
why not post your paypal account here ? ;)) Your comments are so helpful ...and probably take so much of your time...keeping you from "real" work. Or maybe write a book ;)
What I would find very interesting is a list of all your USB children ;))) -> thinking of all the devices you were responsible for. I bet, there are some Tsuneo driven parts in my house :D -> probably not possible due to nda limitations ;((
Vielen Dank! Uli
Hi Tsuneo,
I implemented the changes but it does not seem to be working quite right. I used SimpleHIDWrite to test the new application (loop back on EP1). I hope this is okay? The repeated IN reports have stopped - in fact I did not appear to be receiving any reports at the PC. What I expected to see was the written command followed by a single identical report being read back from the device. I could see the written report but no read report - hence my assessment that the changes are not working ...
I am working with 8 byte packets IN and OUT so I have ...
usbdesc.c /* USB Configuration Descriptor */ /* All Descriptors (Configuration, Interface, Endpoint, Class, Vendor) */ const U8 USB_ConfigDescriptor[] = { /* Configuration 1 */ USB_CONFIGUARTION_DESC_SIZE, /* bLength */ USB_CONFIGURATION_DESCRIPTOR_TYPE, /* bDescriptorType */ WBVAL( /* wTotalLength */ USB_CONFIGUARTION_DESC_SIZE + USB_INTERFACE_DESC_SIZE + HID_DESC_SIZE + USB_ENDPOINT_DESC_SIZE + // added USB_ENDPOINT_DESC_SIZE // added ), 0x01, /* bNumInterfaces */ 0x01, /* bConfigurationValue: 0x01 is used to select this configuration */ 0x00, /* iConfiguration: no string to describe this configuration */ USB_CONFIG_BUS_POWERED /*|*/ /* bmAttributes */ /*USB_CONFIG_REMOTE_WAKEUP*/, USB_CONFIG_POWER_MA(100), /* bMaxPower, device power consumption is 100 mA */ /* Interface 0, Alternate Setting 0, HID Class */ USB_INTERFACE_DESC_SIZE, /* bLength */ USB_INTERFACE_DESCRIPTOR_TYPE, /* bDescriptorType */ 0x00, /* bInterfaceNumber */ 0x00, /* bAlternateSetting */ // 0x01, /* bNumEndpoints */ 0x02, /* bNumEndpoints */ USB_DEVICE_CLASS_HUMAN_INTERFACE, /* bInterfaceClass */ HID_SUBCLASS_NONE, /* bInterfaceSubClass */ HID_PROTOCOL_NONE, /* bInterfaceProtocol */ 0x04, /* iInterface */ /* HID Class Descriptor */ /* HID_DESC_OFFSET = 0x0012 */ HID_DESC_SIZE, /* bLength */ HID_HID_DESCRIPTOR_TYPE, /* bDescriptorType */ WBVAL(0x0100), /* 1.00 */ /* bcdHID */ 0x00, /* bCountryCode */ 0x01, /* bNumDescriptors */ HID_REPORT_DESCRIPTOR_TYPE, /* bDescriptorType */ WBVAL(HID_REPORT_DESC_SIZE), /* wDescriptorLength */ /* Endpoint, HID Interrupt In */ USB_ENDPOINT_DESC_SIZE, /* bLength */ USB_ENDPOINT_DESCRIPTOR_TYPE, /* bDescriptorType */ USB_ENDPOINT_IN(1), /* bEndpointAddress */ USB_ENDPOINT_TYPE_INTERRUPT, /* bmAttributes */ // WBVAL(0x0004), /* wMaxPacketSize */ WBVAL(0x0008), /* wMaxPacketSize */ 0x20, /* 32ms */ /* bInterval */ // 0x01, /* 1ms */ /* bInterval */ /* Endpoint, HID Interrupt Out */ USB_ENDPOINT_DESC_SIZE, /* bLength */ USB_ENDPOINT_DESCRIPTOR_TYPE, /* bDescriptorType */ USB_ENDPOINT_OUT(1), /* bEndpointAddress */ USB_ENDPOINT_TYPE_INTERRUPT, /* bmAttributes */ // WBVAL(0x0004), /* wMaxPacketSize */ WBVAL(0x0008), /* wMaxPacketSize */ 0x20, /* 32ms */ /* bInterval */ // 0x01, /* 1ms */ /* bInterval */ /* Terminator */ 0 /* bLength */ };
usbuser.c static OS_SEM USB_IN_EP1_Semaphore; // semaphore for IN EP1 /* * USB Endpoint 1 Task * Handles USB Endpoint 1 Events */ #if (USB_EP_EVENT & (1 << 1)) __task void USB_EndPoint1 (void) { U16 evt; U32 report_size; // added for (;;) { os_evt_wait_or(0xFFFF, 0xFFFF); /* Wait for an Event */ evt = os_evt_get(); /* Get Event Flags */ if (evt & USB_EVT_OUT) { // OUT EP1 interrupt comes report_size = USB_ReadEP( HID_EP_OUT, &OutReport[0] ); // read out the output report // usually, your firmware parse the output report, here // in this snippet, just copy output report to input one directly, for loopback // SetOutReport(); memcpy( InReport, OutReport, report_size ); // send an input report to IN EP os_sem_wait( USB_IN_EP1_Semaphore, 0xffff ); // wait until IN EP is available // USB_WriteEP( HID_EP_IN, InReport, HID_INPUT_REPORT_BYTES ); // pass it to the endpoint USB_WriteEP( HID_EP_IN, InReport, sizeof(InReport) ); // pass it to the endpoint } if (evt & USB_EVT_IN) { os_sem_send( USB_IN_EP1_Semaphore ); // IN EP1 is free /* GetInReport(); // USB_WriteEP(HID_EP_IN, &InReport, sizeof(InReport)); USB_WriteEP(HID_EP_IN, &InReport[0], sizeof(InReport)); */ } } } #endif /* * USB Core Task * Handles USB Core Events */ __task void USB_Core (void) { #if (USB_CONFIGURE_EVENT || USB_INTERFACE_EVENT || USB_FEATURE_EVENT) U16 evt; #endif for (;;) { os_evt_wait_or(0xFFFF, 0xFFFF); /* Wait for an Event */ #if (USB_CONFIGURE_EVENT || USB_INTERFACE_EVENT || USB_FEATURE_EVENT) evt = os_evt_get(); /* Get Event Flags */ #endif #if USB_CONFIGURE_EVENT if (evt & USB_EVT_SET_CFG) { if (USB_Configuration) { /* Check if USB is configured */ os_sem_init( USB_IN_EP1_Semaphore, 1 ); // IN EP1 is available now /* GetInReport(); // USB_WriteEP(HID_EP_IN, &InReport, sizeof(InReport)); USB_WriteEP(HID_EP_IN, &InReport[0], sizeof(InReport)); */ } } #endif #if USB_INTERFACE_EVENT if (evt & USB_EVT_SET_IF) { } #endif #if USB_FEATURE_EVENT if (evt & USB_EVT_SET_FEATURE) { } if (evt & USB_EVT_CLR_FEATURE) { } #endif } }
hiduser.c BOOL HID_GetReport (void) { /* ReportID = SetupPacket.wValue.WB.L; */ switch (SetupPacket.wValue.WB.H) { case HID_REPORT_INPUT: // GetInReport(); // memcpy(EP0Buf,InReport,sizeof(InReport)); memcpy( EP0Buf, InReport, SetupPacket.wLength ); break; case HID_REPORT_OUTPUT: return (__FALSE); /* Not Supported */ case HID_REPORT_FEATURE: /* EP0Buf[] = ...; */ /* break; */ return (__FALSE); /* Not Supported */ } return (__TRUE); } BOOL HID_SetReport (void) { /* ReportID = SetupPacket.wValue.WB.L; */ switch (SetupPacket.wValue.WB.H) { case HID_REPORT_INPUT: return (__FALSE); /* Not Supported */ case HID_REPORT_OUTPUT: // memcpy(OutReport,EP0Buf,sizeof(OutReport)); memcpy( OutReport, EP0Buf, SetupPacket.wLength ); // SetOutReport(); break; case HID_REPORT_FEATURE: return (__FALSE); /* Not Supported */ } return (__TRUE); }
I did not implement the feature report handling at this stage. I commented everything out in SetOutReport and GetInReport I will continue to check over the code but if you can spot anything obvious or perhaps point me in a certain direction that would be great. I've probably done something silly or missed something! Or possibly SimpleHODWRite not the right program for testing? But I think it should work okay? Many thanks in advance! Gareth.
Gareth,
what compiler for PC are you using? I can send you my bare HID testprogram built with VC6
basically, after device detection and FileOpen it is just a matter of WriteFile/ReadFile, nothing else.
In case you want it, just send me a message via my contact form in order to transfer your mail address. you can find the form if you just take my last name and add .de
regards Ulrich
Hi Tsuneo (and Ulrich)
Thank you for both taking the trouble to read this thread! As you can probably tell - I am a little new to programming for USB and just knowing someone is out there watching is a great comfort!!!
I am delighted to say that I've worked through everything again (and again ...) and I seem to have solved my problems (for now).
a) I was not using the array pointer properly when filling IN EP1 (cut and paste error - doh!!) b) also I may have been using the 'Set Report' command rather then 'Write' command in SimpleHIDWrite program ...
Anyway the main problem was the line of code which sent the copied InReport to the EP.
So I now have looping reports working properly with only one IN report send to the PC on receipt of an OUT report from the PC!!
HOORAY! It's a good step as I now have full control of when IN reports are sent. I now just have to fit the exact functionality required for my project.
I will keep you posted as to how I'm getting on!
MANY THANKS ONCE AGAIN! Best regards, Gareth.
Following my success earlier today I have sorted out the information requests from the host - everything seems to be working very nicely!
I'm about to start work on sending reports when information changes ... In your example snippet you show a dedicated task. I assume that it is okay to place this task pretty much anywhere?
I was going to create a task (which repeats, say every 50ms) for monitoring variable changes and place this in the main part of the application program separate from the USB parts. I assume it's okay to do this? It looks like the use of the semaphore which is set every IN request allows for 'remote' processing of the EP1.
I plan to implement this tomorrow. Any comments you might have would be very welcome!
Congratulation!! I'm glad you got good start of your USB life ;-)
It's right.
