problem starting the application
Hi Guys
I'm working with LPC17xx(on a custom board) along with uvision v4.03 and my JTAG debugger is Segger j-link. The problem is when I download my program(through jlink) It does not start executing unless I enter debug mode and manually tell the debugger to run.i.e the program doesn't start executing on reset(without the debugger). I'm afraid its a hardware problem because when I download the same program with the exact same config to another board(again a custom designed board) I don't see the problem.
I would really appreciate your help. Am I missing something?
PS:Also after downloading the code, when in Project - Options for Target - Debug ,I enter the debugger setting (and uVision communicates with JTAG) the program start executing !
