Hi folks,
I am having trouble with data abort handler for last 2 days. Here is my problem. Working version of my program has
Program size code=106384 RO-data=32 RW-data=944 ZI=4880 No heap With a USR stack size of 0x00000400
Whenever I have inserted a static variable ;
static int abc[7000] ;
Program size code=106384 RO-data=32 RW-data=944 ZI=32880
Which is expected.
In simulator everything is fine, firmware works as expected, but when I have download it to target board, it crashes. Then I debug it and noticed that after jumping to main routine from startup.s file, it drops to Dabthandler.
I have checked the forum and found a method that shows which instruction caused data abort exception. According to this method, my code raises data abort exception at "__fplib_config_pureend_doubles" instruction.
Then I decrease the size of my static array variable to
static int abc[6800] ;
Everything works fine. So I was wondering if anyone could tell me what's wrong here?
Cheers, Deha
