Hi Everyone..
I am a Newbie and just starting to write some programm for my lpc2378. At the moment i am trying to make the PLL Setup Sequence for my LPC2378. unfortunately i can't understand this step from User Manual
.. 4) Write to the clock source selection control register to change the clock souce.
I'd have the Main Oscillator as my Clock Source.
CLKSRCSEL = 0x1; /* select main OSC as the PLL clock source */ PLLFEED = 0xaa; PLLFEED = 0x55;
In User Manual can be read that The main oscillator operates at frequencies of 1 MHz to 24 MHz.
My Question: How can i operate the main oscillator with a constant freq? For example 12 MHz ? I need this constant frequenz, so i can configure my PLL
Anyone can help me??
Thank You
"How can i operate the main oscillator with a constant freq? For example 12 MHz ?"
wouldn't that just be driving it with a 12Mhz external source, or with a 12Mhz crystal?
configuring your PLL is a separate question - and can be done in the start-up file as provided by keil.
My Code doesn't work. I can't not make debugging.. Can someone help me :-)
Thank you..
void initclock(void)
/* Disconnect the PLL */
if ( PLLSTAT & 0x02000000 ) { PLLCON = 0x1; feed (); }
/* Disable PLL */ PLLCON = 0x0; feed ();
/* Selects the main oscillator as the PLL clock source*/ CLKSRCSEL = 0x1;
// Init Main Oscillator // OSCRANGE = 0. The frequency range of the main oscillator is 1 MHz to 20 MHz
SCS &= ~(1<<4); SCS |= (1<<5); // OSCEN = 1. The main oscillator is enabled, and will start up if the correct // external circuitry is connected to the XTAL1 and XTAL2 pins
while (!(SCS & (1<<6))) // Wait until Main Oscillator is ready!
/* select main OSC 12 MHz, Pllclk = 288 MHz */
PLLCFG = 0x0000000B; // N=1, M=12 feed ();
/* Wait until main OSC is usable */ //while( !(SCS & 0x40) );
/* Enable PLL, disconnected */ PLLCON = 0x1; feed ();
/* Fcco = 288M, Fcclk = 288/(3+1) = 72M */ CCLKCFG = 0x03; feed();
//while ( !(PLLSTAT & PLOCK)); /* Wait for the PLL to lock to set frequency*/ while (!(PLLSTAT & (1<<26)));
/* Connect the PLL as the clock source */ PLLCON = 0x03; feed ();
//while ( ((PLLSTAT & (1 << 25)) == 0) ); /* Check connect bit status */
/* Enabling MAM and setting number of clocks used for Flash memory fetch*/
MAMCR = 0x0; //MAM function disabled MAMTIM = 0x3; //MAM fetch cycles are 3 CCLKs in duration MAMCR = 0x2; //MAM function fully enabled */
void feed(void) { PLLFEED=0xAA; PLLFEED=0x55; }
Nobody is likely to be willing to help you unless you post your code using the format tags. Have you considered peeking in a startup file to see what it does? Why re-invent the wheel?
I'm so sorry..
Hier once again:
void initclock(void) { /* Disconnect the PLL */ if ( PLLSTAT & 0x02000000 ) { PLLCON = 0x1; feed (); } /* Disable PLL */ PLLCON = 0x0; feed (); /* Selects the main oscillator as the PLL clock source*/ CLKSRCSEL = 0x1; // Init Main Oscillator SCS &= ~(1<<4); // OSCRANGE = 0. The frequency range of the main oscillator is 1 MHz to 20 MHz SCS |= (1<<5); // OSCEN = 1. The main oscillator is enabled, and will start up if the correct // external circuitry is connected to the XTAL1 and XTAL2 pins while (!(SCS & (1<<6))) // Wait until Main Oscillator is ready! /* select main OSC 12 MHz, Pllclk = 288 MHz */ PLLCFG = 0x0000000B; // N=1, M=12 feed (); /* Enable PLL, disconnected */ PLLCON = 0x1; feed (); /* Fcco = 288M, Fcclk = 288/(3+1) = 72M */ CCLKCFG = 0x03; feed(); while (!(PLLSTAT & (1<<26))); /* Wait for the PLL to lock to set frequency*/ /* Connect the PLL as the clock source */ PLLCON = 0x03; feed (); /* Enabling MAM and setting number of clocks used for Flash memory fetch*/ MAMCR = 0x0; //MAM function disabled MAMTIM = 0x3; //MAM fetch cycles are 3 CCLKs in duration MAMCR = 0x2; //MAM function fully enabled */ }
1) Your code isn't readable. Didn't you speed the notes on how to post source code?
2) Your feed() function doesn't contain any code for disabling interrupts - are all your PLL code run with interrupts disabled? If so - where is it documented? The user manual clearly says that the two feed operations must be two consecutive APB transfers, i.e. that no interrupt may happen in between.
3) What is the reason that you don't make use of the Keil-supplied startup code?
; Clock Setup ------------------------------------------------------------------ IF (:LNOT:(:DEF:NO_CLOCK_SETUP)):LAND:(CLOCK_SETUP != 0) LDR R0, =SCB_BASE MOV R1, #0xAA MOV R2, #0x55 ; Configure and Enable PLL LDR R3, =SCS_Val ; Enable main oscillator STR R3, [R0, #SCS_OFS] IF (SCS_Val:AND:OSCEN) != 0 OSC_Loop LDR R3, [R0, #SCS_OFS] ; Wait for main osc stabilize ANDS R3, R3, #OSCSTAT BEQ OSC_Loop ENDIF LDR R3, =CLKSRCSEL_Val ; Select PLL source clock STR R3, [R0, #CLKSRCSEL_OFS] LDR R3, =PLLCFG_Val STR R3, [R0, #PLLCFG_OFS] STR R1, [R0, #PLLFEED_OFS] STR R2, [R0, #PLLFEED_OFS] MOV R3, #PLLCON_PLLE STR R3, [R0, #PLLCON_OFS] STR R1, [R0, #PLLFEED_OFS] STR R2, [R0, #PLLFEED_OFS] IF (CLKSRCSEL_Val:AND:3) != 2 ; Wait until PLL Locked (if source is not RTC oscillator) PLL_Loop LDR R3, [R0, #PLLSTAT_OFS] ANDS R3, R3, #PLLSTAT_PLOCK BEQ PLL_Loop ELSE ; Wait at least 200 cycles (if source is RTC oscillator) MOV R3, #(200/4) PLL_Loop SUBS R3, R3, #1 BNE PLL_Loop ENDIF M_N_Lock LDR R3, [R0, #PLLSTAT_OFS] LDR R4, =(PLLSTAT_M:OR:PLLSTAT_N) AND R3, R3, R4 LDR R4, =PLLCFG_Val EORS R3, R3, R4 BNE M_N_Lock ; Setup CPU clock divider MOV R3, #CCLKCFG_Val STR R3, [R0, #CCLKCFG_OFS] ; Setup USB clock divider LDR R3, =USBCLKCFG_Val STR R3, [R0, #USBCLKCFG_OFS] ; Setup Peripheral Clock LDR R3, =PCLKSEL0_Val STR R3, [R0, #PCLKSEL0_OFS] LDR R3, =PCLKSEL1_Val STR R3, [R0, #PCLKSEL1_OFS] ; Switch to PLL Clock MOV R3, #(PLLCON_PLLE:OR:PLLCON_PLLC) STR R3, [R0, #PLLCON_OFS] STR R1, [R0, #PLLFEED_OFS] STR R2, [R0, #PLLFEED_OFS] ENDIF ; CLOCK_SETUP
Do note that this code is executed in supervisor mode therefore it is interrupt-safe.
