uv4.21 - breakpoint problems
I just upgraded to uv 4.21 and after doing this I can't seem to use breakpoints on my project.
(I'm using an LPC1788 development board - Cortex-M3)
(I'm using ULINK Pro)
with version 4.20 and the same code I had no problems with breakpoints but now if I have even 1 before I try and run the code I get the following error:
"This target device does not support all the defined breakpoints!
Please reduce the number of breakpoints and start again."
If I try and add a breakpoint while the application is running I get:
"Operation not possible while the target device is executing.
Please stop the target to perform the operation."
I can stop the execution and step through code but no breakpoints.
Does anyone have any ideas?
Thanks.
M
