I am using the RL-TCPnet Webserver based on the "http_demo" and would like to import and export data into a txt-File on the client pc.
Uploading the data from the client was no problem using the post method to submit the form and process it with the cgi function "cgi_process_data" (as seen in the "http_upload example").
My problem is to export the Data (~1kB) to the Client PC to save it in a txt-File (should be made from the browser).
I am using no file system on the webserver and dont want want to use a tftp server (out of ram and rom).
Shouldn't it be possible to send the Data via HTTP?
I wasn't able to find a library function, nor any examples about this.
Any help would be appreciated!
Thanks in advance, Mathias
create a "your_data_txt.cgi" file that looks like this:
c %s
Then in cgi_func output your formatted data. ex:
uint16_t cgi_func (uint8_t *env, uint8_t *buf, uint16_t buflen, uint32_t *pcgi) { uint32_t len = 0; uint8_t id; char buffer[5]; len = sprintf((char *)buf,(const char *)&env[0], "your text data"); return ((uint16_t)len); }
Thanks for your help Marc!
Hoped there was another way, but it works fine.
Now I have problems to edit the http header:
http://www.keil.com/forum/20052/#msg104526
