Hi, I am working with NXP LPC2378.I download the code through flash magic, pin 2.10 is in low,then remove low from pin 2.10,low state is not changed in pin 2.10,reset the controller, code is not executed, pls give solution
You don't think you need tell us if programming succeeded? What do you think we are - mind readers?! Does you program run after programming using JTAG?
