Hi there!
Im having some troubles implementing a DHCP server on a microcontroller.
System Overview: -Webserver (RL-ARM) running on MCBSTM32E -MCBSTM32E connected over UART with a WLAN module (SLIP). -WLAN module creates an ad-hoc network -Laptop is connected to WLAN module
First, I did get the DHCP server running on the MCBSTM32C development board which has an ethernet interface.
Then I tried to port the DHCP server to the MCBSTM32E. I receive the incoming DHCP_DISCOVER messages and the microcontroller seems to send the SLIP packets but I can't see any incoming UDP data on Packetyzer (running on my laptop). (btw I disable the firewall on my laptop.)
To find the problem I simplified the whole thing and used the udp_send function to send some data to an UDP port ("Hello", port 1333). I did receive the data but only after sending a PING to module and even then only at random. It seemed like a timing or a socket allocation problem. I tried various configurations but without a conclusive answer.
My code:
TCP Task
__task void task_tcp (void) { while (1) { main_TcpNet(); dhcp_server(); os_tsk_pass(); } }
DHCP Server
void dhcp_server (){ if (udp_soc == 0) { udp_soc = udp_get_socket (0, UDP_OPT_SEND_CS | UDP_OPT_CHK_CS, udp_callback); udp_open (udp_soc, 67); /*open port*/ } }
UDP Callback
U16 udp_callback (U8 socket, U8 *remip, U16 remport, U8 *buf, U16 len) { /*udp inits*/ U8 remoteip[4] = {255,255,255,255}; U8* sendbuf; unsigned char udp_msg[302]; //302 Bytes ... if(buf[0]==0x01) //check if bootp boot request { ... if(buf[242]==0x01) //check if dhcp discover { ... //send message len = 256; sendbuf = udp_get_buf (len); // for(index=0;index<256;index++) { sendbuf[index] = udp_msg[index]; } udp_send (udp_soc, remoteip, 68, sendbuf, len); } else if(buf[242]==0x03) //check if dhcp request { ... //send message len = 268; sendbuf = udp_get_buf (len); for(index=0;index<268;index++) { sendbuf[index] = udp_msg[index]; } udp_send (udp_soc, remoteip, 68, sendbuf, len); } } return (0); }
Has anyone encountered a similar problem?
Thanks, Christian
