i need to change the starting location of my pgm frm 00h to say,400h..i followed the steps as per mentioned in.... http://www.keil.com/support/docs/189.htm i can see the changed starting location in the memory map file...but when i try to implemnt it on hardware,i get no output probably bcos da execution begins at 00h only...pls help...
Why "probably"?
What tests/investigations/debugging have you done to make certain whether that is or is not the cause?
Only you have your code - nobody else can debug it for you!
'probably' cos i'm not sure...i dont see any other possibility...the program hs been loaded at 0x400 from what i've checkd..the issue being there is no execution happenin...
