i need to change the starting location of my pgm frm 00h to say,400h..i followed the steps as per mentioned in.... http://www.keil.com/support/docs/189.htm i can see the changed starting location in the memory map file...but when i try to implemnt it on hardware,i get no output probably bcos da execution begins at 00h only...pls help...
i've changed the boot vector address to 04(high byte) through Flash Magic and set the status bit..its a simple pgm for a LED to blink...
