Reading compiler options from a file in RealView Compiler
Hello everyone,
I would like to read compiler options from a file, so I followed the links starting here:
http://www.keil.com/support/man/docs/armcc/armcc_BCFFECIG.htm
The problem is that I get this error:
RTX_Conf_LPC23xx.c: error: C3904U: Could not open via file 'smpl_config.dat'.
I followed all the via file syntax rules, particularly regarding -Dsymbol="value" type options and comments, as expressed in this link:
www.keil.com/.../armccref_Babbface.htm
Below is my via file... any hints as to why I am not being able to use it?
Regards,
George Andrew Brindeiro
Robotron Automation and Technology
#  Filename:       smpl_config.dat
#  Revised:        $Date: 2008-05-12 14:13:04 -0700 (Mon, 12 May 2008) $
#  Revision:       $Revision: 17057 $
#  Author:         $Author: lfriedman $
#  Description:    This file supports the SimpliciTI Customer Configuration for End Devices.
#  Copyright 2004-2007 Texas Instruments Incorporated. All rights reserved.
#  IMPORTANT: Your use of this Software is limited to those specific rights granted under
#  the terms of a software license agreement between the user who downloaded the software,
#  his/her employer (which must be your employer) and Texas Instruments Incorporated (the
#  "License"). You may not use this Software unless you agree to abide by the terms of the
#  License. The License limits your use, and you acknowledge, that the Software may not be
#  modified, copied or distributed unless embedded on a Texas Instruments microcontroller
#  or used solely and exclusively in conjunction with a Texas Instruments radio frequency
#  transceiver, which is integrated into your product. Other than for the foregoing purpose,
#  you may not use, reproduce, copy, prepare derivative works of, modify, distribute,
#  perform, display or sell this Software and/or its documentation for any purpose.
#  YOU FURTHER ACKNOWLEDGE AND AGREE THAT THE SOFTWARE AND DOCUMENTATION ARE PROVIDED “AS IS”
#  WITHOUT WARRANTY OF ANY KIND, EITHER EXPRESS OR IMPLIED, INCLUDING WITHOUT LIMITATION, ANY
#  WARRANTY OF MERCHANTABILITY, TITLE, NON-INFRINGEMENT AND FITNESS FOR A PARTICULAR PURPOSE.
#  IN NO EVENT SHALL TEXAS INSTRUMENTS OR ITS LICENSORS BE LIABLE OR OBLIGATED UNDER CONTRACT,
#  NEGLIGENCE, STRICT LIABILITY, CONTRIBUTION, BREACH OF WARRANTY, OR OTHER LEGAL EQUITABLE
#  THEORY ANY DIRECT OR INDIRECT DAMAGES OR EXPENSES INCLUDING BUT NOT LIMITED TO ANY
#  INCIDENTAL, SPECIAL, INDIRECT, PUNITIVE OR CONSEQUENTIAL DAMAGES, LOST PROFITS OR LOST
#  DATA, COST OF PROCUREMENT OF SUBSTITUTE GOODS, TECHNOLOGY, SERVICES, OR ANY CLAIMS BY
#  THIRD PARTIES (INCLUDING BUT NOT LIMITED TO ANY DEFENSE THEREOF), OR OTHER SIMILAR COSTS.
#  Should you have any questions regarding your right to use this Software,
#  contact Texas Instruments Incorporated at http://www.TI.com.
#/* Number of connections supported. each connection supports bi-directional
# * communication.  Access Points and Range Extenders can set this to 0 if they
# * do not host End Device objects
'-DNUM_CONNECTIONS=2'
#/*  ***  Size of low level queues for sent and received frames. Affects RAM usage  ***  */
#/* AP needs larger input frame queue if it is supporting store-and-forward
# * clients because the forwarded messages are held here. Two is probably enough
# * for an End Device
'-DSIZE_INFRAME_Q=2'
#/* The output frame queue can be small since Tx is done synchronously. Actually
# * 1 is probably enough. If an Access Point device is also hosting an End Device
# * that sends to a sleeping peer the output queue should be larger -- the waiting
# * frames in this case are held here. In that case the output frame queue should
# * be bigger.
'-DSIZE_OUTFRAME_Q=2'
#/* This device's address. The first byte is used as a filter on the CC1100/CC2500
# * radios so THE FIRST BYTE MUST NOT BE either 0x00 or 0xFF. Also, for these radios
# * on End Devices the first byte should be the least significant byte so the filtering
# * is maximally effective. Otherwise the frame has to be processed by the MCU before it
# * is recognized as not intended for the device. APs and REs run in promiscuous mode so
# * the filtering is not done. This macro intializes a static const array of unsigned
# * characters of length NET_ADDR_SIZE (found in nwk_types.h). the quotes (") are
# * necessary below unless the spaces are removed.
'-DTHIS_DEVICE_ADDRESS="{0x79, 0x56, 0x34, 0x12}"'
#/* device type */
-DEND_DEVICE
#/* For polling End Devices we need to specify that they do so. Uncomment the
# * macro definition below if this is a polling device. This field is used
# * by the Access Point to know whether to reserve store-and-forward support
# * for the polling End Device during the Join exchange.
#/* -DRX_POLLS */
