Hello , all I want to interface a DS1307 to arm7 via TWI . can anyone help me. have nice time Amir
Help you with what? Solder? Read the manuals? Write your code? Test it for you?
How to interface anything to anything else:
www.8052.com/.../160143
Hello per
Baravo hahahahahahahah
LOL
cant say any thing.
every day you can make me laugh.
how to interface TWI in RTX-OS. if you have sample program send it tome
your sincerely,Amir
"how to interface TWI in RTX-OS"
You didn't mention RTX-OS in your initial post.
For specific details about RTX-OS you will, obviously, have to study the RTX-OS Manuals
TWI doesn't really require any interfacing with any OS unless you move up to "PC-class" operating systems where your only access to hardware is through a driver.
In your case, you can use just about any TWI code for your specific processor. For most processors that have hardware support for it, it would be natural to use an interrupt-driven approach where you might have a send buffer and a receive buffer. Then you can use one of the OS primitives to signal a task whenever there is data available in the receive buffer.
Tasks that needs to send can insert data in the transmit buffer. Then it's required to check if the interface is active (so a future interrupt will draw data from the transmit buffer) or if you need to kick-start the transfer. That can also be done using a separate task that gets a signal everytime data have been added to the transmit buffer. Or it can be done by each calling task if you just have a critical section that protects many tasks from concurrently checking if TWI is active before deciding to kick-start the device.
Thanks very much Andrew. will test with this method. Amir
hello Per Oh finally you make me help
Given that your help isnt good, but Thank you very much for your Attention
i think keil library is very poor
in last time im work with Bascom-AVR , its library is very full. Bascom make me very Lazy.
have nice time your sincerely , Amir
I'm not sure that you can blame Bascom entirely for that...
hi,Andrew
You are right
Bascom is really OK, I like it. we work in our company with bascom now. but in this time i want to introduction new controller to my employees,
i hope keil compiler complate its lib.
have nice time friend. Amir
I think it's more likely to be your expectations that need revising.
Bascom is a very specific environment for just one specific target; Keil is much more general-purpose and, therefore, cannot provide such fine-detail support for every conceivable different platform.
Yea,Andrew you are fully right
when i thinking about keil's supported microcontroller, i go to clear , really right i think support around 2~3000 different type of uC ,yea , this is very hard.
sorry for my bad english but seem that keil can be lovely, have good support team.
i am thinking to make a forum for keil , interrest on Atmel product.
Can your team help me,
