Does #pragma pack(n) apply to all the structures in a source code or it has to be applied to each structure separately ? It's not clear from the manual. In one place it says: "You can use #pragma pack(n) to make sure that any structures with unaligned data are packed." In other: "This pragma aligns members of a structure to the minimum of n"
Hi Andy and Per,
Many thanks for your helps.
I will do some more study on this.
