Hi, I have a structure initialized in a flash
struct DEFSTRUCT const str_default;
I also have an assembly module which loads a binary file:
AREA defprog_00111, CODE, READONLY, PREINIT_ARRAY EXPORT EXT_Default_profile EXT_Default_profile INCBIN E:\Aprojects\default_30.bin ; includes file END
How can I initialize the structure str_fefault to the loaded binary file ? I am trying to avoid an absolute placement of a structure.
I tried to search for possible solution, but no luck, or maybe I missed something.
Thank you, Gennady
If I understand the question correctly, then I think what you want is:
extern struct DEFSTRUCT const str_default;
and
AREA defprog_00111, CODE, READONLY, PREINIT_ARRAY ; EXPORT EXT_Default_profile ;EXT_Default_profile EXPORT str_default str_default INCBIN E:\Aprojects\default_30.bin ; includes file END
Then the contents of 'str_default' are defined by the file 'default_30.bin'.
Be careful: having the structure data external to the program (that is, in a file) is a fragile thing. Any change to the structure type could invalidate your data file.
You might well be better off expressing the structure value as a C initialization:
struct DEFSTRUCT const str_default = { /* ... member values here ... */ };
