LPC2148 ADC working but incorrectly
hey
i am using LPC 2148. and configured the hardware for taking the analog signal at P0.28 which is ADC0 channel 1.
i am using following code but the output stays 0 or 1023 only.
my hardware connections are verified with several ready made boards and kits for the same controller..
kindly check and help for my problem..
thanks
#include<lpc214x.h>
#include<stdio.h>
//VPB clock 30Mhz
void delay(int);
extern long val,stat,s;
extern long adc_val;
int main()
        serial_init();
        clear_arrays();
        adc_init();
        //printf("MISSAR SYSTEMS\n\n");
        while(1)
                adc_read();
                printf("%i\n",adc_val);
                delay(1000);
void adc_init(void)
        PINSEL1 = 0x01000000;   // P0.28 - AD0.1
        PCONP |= 0x00001000;
        AD0CR &= 0x00000000;
        AD0CR |= 0x00201302; // with clock = PCLK/(7+1) = 30Mhz/8 = 3.75Mhz
        AD0INTEN &= 0x00000000;
void adc_read(void)
        AD0CR |= 0x01000000;    // Start AD conversion NOW on AD0.1 (P0.28)
        delay(100);
        do
                val = AD0DR1;    // Get value
        } while ((val & 0x80000000) == 0);  // until bit 31 is high (DONE)
        val = (val>>6);
        adc_val = val & 0x3FF;       // Extract AD result
void delay(int delay_value)
        int out_delay=0,in_delay=0;
        for(out_delay=0 ; out_delay < delay_value ; out_delay++)
                for(in_delay=0 ; in_delay <= 1000 ; in_delay++);
  • Hi
    In this part
    you assign the ADC register to a variable and then you use a while on that variable which will never change.
    You have to use the actual register in the while loop to detect when you have a result.
    Alex
  • Hi
    In this part
    Alex
