Hi
when downloading i get the error message "Cannot enter Debug Mode" is any one know whats the problem.
best regards
I doubt that, there can be many reasons, you need to do some investigation and post the results.
Hi Im working with LM3S8933 microcontroler in my own bord i using the keil development tool with uv4 editor and ulink 2 debugger. The bord working in 8MHz frequency. I succeed to download the programm in the first time but after the first time i get the error messages "Cannot enter Debug Mode" and "cannot access memory". thank's. The debug setting is JTAG.
Thank's.
LM3S8933 microcontroler don't know that one, but a "universal issue" is: do you happen to set some protection bits. If you set the "code protection" "code theft protection" "code read protection" whatever they are called bits the debugger can not work.
I think it is more likely that he set the clock(s) to a frequency that disables JTAG (some devices have that).
