Hi All,
I've got this problem about Uvision debugger jumping suddenly to nowhere when I stepped through the code, and this somehow leads to data abort. But if I don't do stepping but just simply running it, I don't encounter the problem. Starting-stopping the running program also leads to data abort.
Anybody encountered this before? Is this somehow related to an interrupt triggering even when the core is stopped?
Thanks, LFO
My problem seems to be similar to this: http://www.keil.com/forum/16791/. Anyone experiencing this same problem?
It happens when you use the WatchDog while debug. Turn it off (Don't start it in Debug)
Thank you very much Doron, it has fixed the problem. For some reason I thought I already disabled the WDT but after I saw your post, I checked back my code again and I saw that it was indeed still enabled. Thanks a lot!
