I am writing a GPIO input object that reads the pinstate of GPIO port 0. I am putting in a feature where the different pull resistor states can be specified. They are done so with an enum type in the header. One problem, the code has no effect. The default state of the pin does not change. I am almost certain the values in the pinmodes are right as I checked them with the debugger. I have a feeling there is something simple I am overlooking.
switch(GetPullType()) // Connect specified pull resistor. { case PULLDOWN: LPC_PINCON->PINMODE0 |= (1 << gPinNumber); LPC_PINCON->PINMODE0 |= (1 << gPinNumber + 1); break; case PULLUP: LPC_PINCON->PINMODE0 &= ~(1 << gPinNumber); LPC_PINCON->PINMODE0 &= ~(1 << gPinNumber + 1); break; default: LPC_PINCON->PINMODE0 &= ~(1 << gPinNumber); LPC_PINCON->PINMODE0 |= (1 << gPinNumber + 1); break; }
I checked the inputs with a volt meter. Here is what I read in each mode for any specified pin:
PULLDOWN = 4.3 volts PULLUP = 4.36 volts PULLNONE = 4.35 volts
According to these voltages, the default pullup mode is not changing. I am using the LPC1768 controller with an MCB1700 development board.
Could there be something wrong with the board + chip? 3 something volts seems a little high.
I did some more playing around by breaking the program down to its simplest form. What I am trying to do is read the state of a momentary push button connected from VCC to the pin. The pin is supposed to be pulled down. The problem is when I attempt to enable the pull down resistor, the input behaves is if it were pulled up (the led turns off when the input is grounded). What is going on? Here is the code I am running:
#include <stdio.h> #include <LPC17XX.h> int main(void) { LPC_GPIO1->FIODIR |= 1 << 28; // Make P1.28 an output. LPC_GPIO0->FIODIR &= ~(1 << 0); // Make P0.0 an input. LPC_PINCON->PINMODE0 = 0x03; // Pull P0.0 down. while (1) { if (LPC_GPIO0->FIOPIN & (1 << 0)) // Read state of P0.0. { LPC_GPIO1->FIOSET |= 1 << 28; // Make P1.28 high. LPC_GPIO1->FIOCLR &= ~(1 << 28); } else { LPC_GPIO1->FIOCLR |= 1 << 28; // Make P1.28 low. LPC_GPIO1->FIOSET &= ~(1 << 28); } }
