I am trying to add the Silicon Labs Si1000 in the list of devices in uVision 4. Silicon Labs has a driver for uVision that is supposed to provide the Si1000 support. I have downloaded and run the installation but the Si1000 device still does not show up in the device database.
This device is not yet added to the Keil Device Database.
You will have to add it manually.
http://www.keil.com/support/docs/1421.htm
The Keil tools will work with the SI1000 device - Si Labs provides examples for this device that compile using the Keil compiler here:
www.silabs.com/.../Si1000DK.aspx
click on the 'AN474SW: Si10xx Code Examples'
Also, if you are using the Keil IDE, with the Silicon Labs EC2 hardware, you will need the Silicon Laboratories, Inc. uVision Driver for SiLABS Debug Hardware
http://www.keil.com/uvision/agdi/187.htm
