hi... i want help about keil programming i make data acquisition system using lpc2148 i want to save all data in to sd card & also send it to pc to display in labview pls any1 help me
What have you done so far?
i done hardware but programming is not done yet
But what work have you done on the software. What have you written? What have you been planning for? What have you been googling for? Where are you stuck?
What is it specifically about Keil that you need help with?
Are you familiar with programming in general?
Are you familiar with embedded programming in general?
Lots of specific Keil help to be found here: http://www.keil.com/support/man_arm.htm
And here: http://www.keil.com/support/
See also: http://www.keil.com/books/
i dont know about programming pls help me & give me any reference who will give me program directly
So you have grown up assuming that because you can get (sometimes through illegal copying) programs to you PC, you can also just ask for ready-to-run programs for embedded equipment?
Sorry, but why do you think that? You have already "done hardware". Why do you expect anyone to have runnable program for your hardware? Why do you expect someone who have source code that may adaptable to your hardware spend time helping you to adapt it to your hardware? Or even give you that code in the first place?
Don't you realize that lots of people on this forum have this as our occupation? We make it for money.
If you don't know anything about programming, then you should look around for existing projects on the net, and don't buy or build hardware unless you have already found available - and free - software that you can download for that hardware.
You never start with hardware without having already solved the "how to" about the software. That would be like buying an helicopter first and then trying to figure out how much it would cost to get a license to fly it.
