Demo Or New Version?
I get this when I compile/link a project that DOES work on my system at home.
At home, I have the full uVision3 system, where as at work we are [still] using the 'new' Demo version.
My question is 'simple'... are these linker errors due to the EVAL/Demo version or the 'new' uVision V4.03q?
linking...
BrusselsV1.axf: Error: L6218E: Undefined symbol os_fifo (referred from p1120-3).
BrusselsV1.axf: Error: L6218E: Undefined symbol os_fifo_size (referred from p1120-3).
BrusselsV1.axf: Not enough information to produce a FEEDBACK file.
BrusselsV1.axf: Not enough information to list image symbols.
BrusselsV1.axf: Not enough information to list the image map.
BrusselsV1.axf: Finished: 3 information, 0 warning and 2 error messages.
Target not created
Or is it that the Demo version won't allow the RTX support?
--Cpt. Vince Foster
2nd Cannon Place
Fort Marcy Park, VA
P.S. I tried tacking this onto:
http://www.keil.com/forum/docs/thread17370.asp
but it doesn't seem to show up.
Parents Reply
  • FYI. (might be useless to you, Captain.)
    http://www.keil.com/update/relnotes/RLARMV405.HTM
    RL-ARM Version 4.05
    Release Date: 28 January 2010
        * [RTX Enhancements]
          Added: configurable FIFO Queue size for ISR requests in RTX_Config.c configuration file.
          Added: runtime error function os_error() to RTX_Config.c file. The runtime error codes are defined in RTL.h
        * [RTX Problems solved]
          Corrected: a problem in Round Robin task switching. This failed if a robin task was suspended by a higher priority task.
          Corrected: Stack checking did not work on system tick timer interrupt, only on preemptive task switches.
          Corrected: task switch monitoring in RT Agent did not work for Round Robin task switching.
          Corrected: incorrect event flag clearing in os_evt_wait_and() function if event flags were set separately. The following example shows the problem.
