Hi, I am trying to use the "Mode" command to send the serial data to the COM port, however, when i type in the command widow: mode com1 9600,0,8,1 it says: mode com1 command failed
so does anyone know the solution to this problem? thank u
Is something else using COM1 ?
In Windows, check the Device Manager -> Ports. You will get this error if there is no COM1 port.
