Using asm variable in C
Hello!
In my project in Keil i am using mixing programming C and ASM with working inline assembler.
I have some problems to access variable define in asm from C.
I define variable in module spi (spi.src file)
NAME SPI
?DT?spi_vars?SPI SEGMENT DATA
PUBLIC ADC1H,ADC1L,DAC2H,DAC2L
RSEG ?DT?spi_vars?SPI
ADC1H DATA 0x32
ADC1L DATA 0x33
DAC2H DATA 0x34
DAC2L DATA 0x35
?BT?spi_bit_vars?SPI SEGMENT BIT
PUBLIC SPI_num
RSEG ?BT?spi_bit_vars?SPI
SPI_num BIT0x24.1
and define this variable using C (file main.h included in main.c)
extern data unsigned char DAC2H;
extern data unsigned char DAC2L;
extern data unsigned char ADC1H;
extern data unsigned char ADC1L;
extern bit SPI_num;
But when i try using this variable i get error
main.src(250): error A45: UNDEFINED SYMBOL
Also i try using inline assembler in my main.c file
EXTRN DATA (DAC2H,DAC2L,ADC1H,ADC1L)
EXTRN BIT  (SPI_num)
but get error:
CLASSES (XDATA (X:0x0-X:0x7FF), HDATA (X:0x0-X:0x7FF), CODE (C:0x0-C:0x7FFF), CONST (C:0x0-C:0x7FFF),
ECODE (C:0x0-C:0x7FFF), HCONST (C:0x0-C:0x7FFF))
*** ERROR L220: INVALID INPUT MODULE
    MODULE:  main.obj (MAIN)
question :
How to correct access to assembler variable fro C with working inlin assembler or without.
  • . I am partially solved this problem i am add absolute location on my variable defined
    example
    extern data unsigned char DAC2H _at_ 0x32;
    extern data unsigned char DAC2L.......;
    extern data unsigned char ADC1H.......;
    extern data unsigned char ADC1L.......;
    extern bit SPI_num;!!!!!!!!!!!
    but no solve problem with SPI_num, becouse _at_ no implemented for bit variable in C51.
    maybe who knows how sole this problem???
    Thanks!!
