void main(void) { unsigned char sec, min, hour, date, month, year; Sys_Init(); watch_dog(); DS1307_init(); //DS1307_settime(0x67,0x45,0x00); /* Set Time (hh:mm:ss) */ //DS1307_setdate(0x03,0x08,0x06); /* Set Date (dd/mm/yy) */ while (1) { watch_dog(); /* Get Date & Time */ sec = DS1307_get(SEC); min = DS1307_get(MIN); hour = DS1307_get(HOUR); date = DS1307_get(DATE); month = DS1307_get(MONTH); year = DS1307_get(YEAR); } } void DS1307_init(void) { I2C_start(); I2C_write(DS1307_ID); I2C_write(0x00); //I2C_write(0x7F); //I2C_write(0x80); I2C_write(0x00); I2C_stop(); datas[0]='I'; com_t_index=0; com_t_length=1; TX_RX=1; watch_dog(); TI=1; } unsigned char DS1307_get(unsigned char addr) { unsigned char ret; DS1307_init(); I2C_start(); /* Start i2c bus */ I2C_write(DS1307_ID); I2C_write(IN); I2C_write(IN); I2C_stop(); I2C_write(DS1307_ID); /* Connect to DS1307 */ I2C_write(addr); /* Request RAM address on DS1307 */ I2C_start(); /* Start i2c bus */ I2C_write(DS1307_ID+1); /* Connect to DS1307 for Read */ ret = I2C_read(); /* Receive data */ //I2C_noack(); //delay_10ms(10); I2C_stop(); /* Stop i2c bus */ return ret; datas[0]=hextoascii((ret>>4)&0x0F); datas[1]=hextoascii((ret)&0x0F); com_t_index=0; com_t_length=2; TX_RX=1; watch_dog(); TI=1; } void DS1307_settime(unsigned char hh, unsigned char mm, unsigned char ss) { I2C_start(); I2C_write(DS1307_ID); /* connect to DS1307 */ I2C_write(0x00); /* Request RAM address at 00H */ I2C_write(ss); /* Write sec on RAM address 00H */ I2C_write(mm); /* Write min on RAM address 01H */ I2C_write(hh); /* Write hour on RAM address 02H */ //delay_10ms(10); I2C_stop(); /* Stop i2c bus */ } void DS1307_setdate(unsigned char dd, unsigned char mm, unsigned char yy) { I2C_start(); I2C_write(DS1307_ID); /* connect to DS1307 */ I2C_write(0x04); /* Request RAM address at 04H */ I2C_write(dd); /* Write date on RAM address 04H */ I2C_write(mm); /* Write month on RAM address 05H */ I2C_write(yy); /* Write year on RAM address 06H */ //delay_10ms(10); I2C_stop(); /* Stop i2c bus */ } void I2C_delay(void) { unsigned char i; for(i=0; i<I2C_DELAY; i++); } void I2C_clock(void) { I2C_delay(); SCL_1 = 1; /* Start clock */ I2C_delay(); SCL_1 = 0; /* Clear SCL */ } void I2C_start(void) { if(SCL_1) SCL_1 = 0; /* Clear SCL */ SDA_1 = 1; /* Set SDA */ SCL_1 = 1; /* Set SCL */ I2C_delay(); SDA_1 = 0; /* Clear SDA */ I2C_delay(); SCL_1 = 0; /* Clear SCL */ } void I2C_stop(void) { if(SCL_1) SCL_1 = 0; /* Clear SCL */ SDA_1 = 0; /* Clear SDA */ I2C_delay(); SCL_1 = 1; /* Set SCL */ I2C_delay(); SDA_1 = 1; /* Set SDA */ } bit I2C_write(unsigned char dat) { bit data_bit; unsigned char i; for(i=0;i<8;i++) /* For loop 8 time(send data 1 byte) */ { data_bit = dat & 0x80; /* Filter MSB bit keep to data_bit */ SDA_1 = data_bit; /* Send data_bit to SDA */ I2C_clock(); /* Call for send data to i2c bus */ dat = dat<<1; } SDA_1 = 1; /* Set SDA */ I2C_delay(); SCL_1 = 1; /* Set SCL */ I2C_delay(); data_bit = SDA_1; /* Check acknowledge */ // I2C_ack(); SCL_1 = 0; /* Clear SCL */ I2C_delay(); return data_bit; /* If send_bit = 0 i2c is valid */ } unsigned char I2C_read(void) { bit rd_bit; unsigned char i, dat; dat = 0x00; for(i=0;i<8;i++) /* For loop read data 1 byte */ { I2C_delay(); SCL_1 = 1; /* Set SCL */ I2C_delay(); rd_bit = SDA_1; /* Keep for check acknowledge */ dat = dat<<1; dat = dat | rd_bit; /* Keep bit data in dat */ SCL_1 = 0; /* Clear SCL */ } return dat; } void I2C_ack() { SDA_1 = 0; // Clear SDA I2C_delay(); I2C_clock(); //Call for send data to i2c bus SDA_1 = 1; // Set SDA } void I2C_noack() { SDA_1 = 1; // Set SDA I2C_delay(); I2C_clock(); // Call for send data to i2c bus SCL_1 = 1; // Set SCL } unsigned short int hextoascii (unsigned char c) { unsigned char ch = c; unsigned char as1; unsigned char as2; // take the char and turn it to ASCII as1 = ch; as1 >>= 4; as1 &= 0x0F; if ( as1<10 ) as1 += 48; else as1 += 55; as2 = ch; as2 &= 0x0F; if ( as2<10 ) as2 += 48; else as2 += 55; return( ((unsigned short int)(as1)<<8) + as2 ); }
thank u sir.there is one problem with the pin in hardware i got the output thank u..........
What pin?
What was the problem?
Please share for the benefit of others who might have the same problem...
http://www.keil.com/forum/19535/
Before you expect more help, how about contributing?
homepage.ntlworld.com/.../now-help-others.html
