Hi there,
I am using MCB1700 board. Last time I had loaded the sample program as it which is known as LCD_Blinky. It was working fine.
Without making any changes I had compile the program and I got the following error.
linking... .\Flash\Blinky.axf: error: L6047U: The size of this image (207581 bytes) exceeds the maximum allowed for this version of the linker Target not created
Please help me regarding this
Thanks in advance
Not all examples can be rebuilt with the evaluation version of the compiler tool set.
So, we can't really help you. You either have to settle for running the existing examples as-is, only work with smaller examples (or remove code from existing examples) or buy a commercial edition of the Keil tools.
The question here is - exactly what help did you expect?
First of all sorry for the late reply. I have edited a sample file coding but unfortunately I was not able to compile it as I am having uVision 4 evaluation version. Can u please compile it for me.
www.megaupload.com/
Please be kind enough to help me. I would be much obliged if you can help me in this issue.
Best Regards.
