Im made a test program without function to test speed of the Cortex, downloader, debugger and compiler. MCB1700 board Program worked well. To continue with testing i added some files to increase the size of the project (Hash functions). The files are included but the function is never real called. The call has been place at a location where the main program never comes. So the function of the program should be the same as before. No compile errors, no download errors, program is ready to run Source
; Reset Handler Reset_Handler PROC EXPORT Reset_Handler [WEAK] IMPORT __main LDR R0, =__main BX R0 ENDP
Disassembly
124: LDR R0, =__main 0x00000260 4808 LDR r0,[pc,#32] ; @0x00000284 125: BX R0 126: ENDP 127: 126: ENDP 127: 128: 129: ; Dummy Exception Handlers (infinite loops which can be modified) 130: 131: NMI_Handler PROC 132: EXPORT NMI_Handler [WEAK] 0x00000262 4700 BX r0 133: B . 134: ENDP
R15 (PC) = 0x00000260 Doing one assembler step and: R15 (pc) = 0x00000262, R0 = 0x000000cd Why 0x000000cd ?? and not 0x00000284
Doing one more step and i am in the middel of one of my realtime routines? at an even adres.
2293: // Test mode 2294: 0x000000CC F000F802 BL.W __scatterload_rt2_thumb_only (0x000000D4) 2122: os_evt_set (mouse->InputsEvent, mouse->InputsTaskId); // 0x000000D0 F000F8B6 BL.W __rt_entry_sh (0x00000240) 0x000000D4 A00A ADR r0,{pc}+4 ; @0x00000100 2297: if (Config.mode == 1) // 2298: {
Something is going wrong at compilation time i think and the reason must be the pre-init routines needed for RAM (done by the compiler), however this should never happen or is this another feature of the Cortex M3 i overlooked
