Debugger in uVision3 V4.00a can not load AXF file - Keil
Recently I bought SEGGER J-link JTAG.
Today I installed it on my computer.
Flash download works fine, but when I try to debug I got this message:
Error: Could not load file 'xxx.AXF'
Debugger aborted !
ps.
I found this similar post http://www.keil.com/forum/12732/,
where a guy is explaining the same problem, only he is using EK-LM3S8962 evaluation board.
I downloaded file that had helped him ("TLM.dll"), but it was no help to me.
KEIL INFO:
Tool Version Numbers:
Toolchain: RealView MDK-ARM Version: 4.01
Toolchain Path: BIN40\
C Compiler: Armcc.Exe V4.0.0.524 [Evaluation]
Assembler: Armasm.Exe V4.0.0.524 [Evaluation]
Linker/Locator: ArmLink.Exe V4.0.0.524 [Evaluation]
Librarian: ArmAr.Exe V4.0.0.524 [Evaluation]
Hex Converter: FromElf.Exe V4.0.0.524 [Evaluation]
CPU DLL: SARMCM3.DLL V4.01
Dialog DLL: DARMP1.DLL V1.11a
Target DLL: Segger\JL2CM3.dll V1.05g
Dialog DLL: TARMP1.DLL V1.11a
  • i have the same problem. i test it and then can work. you can go to the "option for target Flash"
    option "Utilities" and enable "update target before debugging".compile, should be working.and then you can disable "update target before debugging" again,debugger will load the axf file.
    i try many times, you can try it.
    good luck.(my english is bad~~ so~~~~~^^ read hard??)
