Hello i have wrote the above code but i use inline assembly to... is any other better way to get the same result ? i try to read busy flag from a glcd and switch block
void block(unsigned char cs) { bit busy = 1; if(cs == 1) cs1=1; else cs2=1; #pragma asm mov auxr,#0x0e ;disable XRAM from 0x00 to 0xff mov r0,#check_status busy: movx a,@r0 ;read busy flag jb acc.7,busy mov auxr,#0x0c ;enable XRAM #pragma endasm cs1=0; cs2=0; }
thanks a lot
