I could not find an API for RTX to get the current ticks. I need to know that information in order to measure the performance.
The tick rate is a part of RTX's configuration. Why do you need something during runtime that you configure in RTX_config.c ?
I don't need to change it, I only need the ticks number so I can calculate the time for some operation such as
start = os_ticks_get(); do something here end = os_ticks_get();
then end - start is the time.
I need to find out the API for os_ticks_get()
in rt_time.h....
extern U16 os_time;
