Volatile struct members
I would like to prevent structure members optimization. I used volatile keyword:
typedef volatile struct
    volatile ...
    volatile uint32_t discard;
    volatile ...
} regs_t;
I declared a member in another non-volatile struct:
typedef struct
    volatile regs_t *regs;
} peripheral_t;
I used an "empty" expression to just clear flags in register (the memory read access must be performed):
peripheral_t p;
p.regs = 0x12345678; /* init to register block starting address */
p.regs->discard;     /* gets optimized out when opt. is on      */
The "empty" expression gets optimized out although I thought (hoped) I prevented it via the volatile keywords.
- What is the right place to put the volatile?
- Does the whole struct have to be volatile?
- Does it make sense to define volatile type? (typedef volatile struct...)
Thanks for tips/explanations.
Regards Pavel
