hello together, I use as a newbie XE167 + Dave 2.2 r1 + µV4 . I just want to use the simulator for hands-on training on infineon-HOT_XE164_ASC homepage. When I debug, error is: *** error 65: access violation: addr = 0x0000F600 I google the error, but no success. could someone help me? Thanks in advance
sorry for my english!
I had the same problem but with different address 0x000A00. The simulator tried to execute the code from the RAM. You need to load a ini-File in the Debug Option (in Target Option)
Write these lines in your ini-File: MAP 0x00A000, 0x00DFFF EXEC READ WRITE MAP 0x00F600, 0x00FDFF EXEC READ WRITE
Define as well for your external RAM, if necessary!
