I've never done a USB Host interface before, now I am trying to enumerate USB Host using NXP's USBHostLite example using LPC1768 controller.
It stuck at "while (!HOST_RhscIntr);"
I got a short serial output followed by flashing
---------------------------- Initializing Host Stack Host Initialized Connect a Mass Storage device -----------------------------
Can anybody tell me why
"LPC_USB->OTGStCtrl = 0x3;" statement is using. And if I use "LPC_USB->OTGStCtrl = 0x203;" this statement then serial output is followed as
------------------------------------ Initializing Host Stack Host Initialized Connect a Mass Storage device ERROR: In Host_EnumDev at Line 358 - rc = -1 ---------------------------------------------
The line (Line 358 in usbhost_lpc17xx.c) is this block of code:
rc = HOST_GET_DESCRIPTOR(USB_DESCRIPTOR_TYPE_DEVICE, 0, TDBuffer, 8); if (rc != OK) { PRINT_Err(rc); return (rc); }
Could it be an issue with my USB drive or hardware?
Many thanks in advance,
-Prakash 9886545216
1. If you have any USB snooper, connect and get the log which is ease to debug. 2. Check your pendrive with PC, whether it is working or not.
After this basic debugging, we can go further into the code.
Regards, D.
I don't have USB snooper. I have checked the pendrive. That was working fine with my PC.
