sir,
I have checked as per your suggestion.
I am using 'SIMCOM300' module.
I am receiving every new message indication from gsm module as in the form of +CMTI: "SM", index.
can I check whole string "+CMTI"?
I think it will more accurate.
but sir, still problem is that
if 2 or more sms receive sequentially then indication will be..
+cmti: "SM", 1 +cmti: "SM", 2 +cmti: "SM", 3
& my buffer size for this is only 12 bytes. so after getting string '+cmti: "SM", 1' in buffer the flag bit will set. this will know the controller that new message index is received.
thus the index will give to +cmgr command for reading new message content.
Then again the message content store in separate buffer.
but if more indication at a time, controller will save data like.... '+cmti: "sm" ok' etc so here index will missed & controller take garbage as index
