Hi there
I am using the Keil MCB1700 board with an LPC1768 processor. I am currently writing data to a USB memory stick at regular intervals using the Keil file libraries, but I am having problems as the speed at which I can write is very limited. I thought that it may be possible to write quicker if DMA were activated, but I can't work out how I activate DMA in the Keil libraries. Does anyone know how I could do this?
Thanks in advance, Richard
You probably need to either ask Keil if they implemented it (not ,AFAIK), or do it yourself, which requires you to obtain the sources after you sign a Non-Disclosure Agreement.
Sorry, I don't understand..
Sign a NDA...
