atof() function problem
I am using keil IDE for arm7 (LPC2138 by NXP) programming.
Here is my code.
#include <LPC213X.H>
#include "Stdlib.h"
#include "Serial.h"
void initialize(void);
int main () { float number; int i;
initialize(); UART0_sendstring("Here 1\r\n");
number = atof("643.783");
UART0_sendstring("Here 2\r\n");
while(1){}
Program compiles successfully.Only 2 warnings:
main_testProj2.c(51): warning: #550-D: variable "number" was set but never used
main_testProj2.c(52): warning: #177-D: variable "i" was declared but never referenced
Now when i simulate the code on Hardware. Only "Here 1\r\n" string is displayed on HyperTerm. "Here2\r\n" is not Displayed at All.
If i replace the argument string of atof() with something like this >> number = atof("6.3e+2");
then the program works fine. Both the strings are displayed in respective order.
What i concluded:
In first case, The program enters into the atof function but it never comes back, looks like it hangs somewhere inside the atof() function. Why?
