problem with debugger start address
I have Cortex-M3 and encountered problems when using scatter file: (I just want to keep space 4kb at the beginning of the code space)
LR_IROM1 0x08000000 0x01000{ ER_IROM1 0x08000000 ABSOLUTE EMPTY 0x1000 { ;0x1000 empty space }
LR_IROM2 0x08001000 0x3F000{ ER_IROM2 0x08001000 ABSOLUTE 0x3F000{ STM32F10x.o(RESET, +First) ; vector table *.o(+RO) *(InRoot$$Sections) }
RW_IRAM2 0x20000000 0x0000C000 { ; RW data *.o(+RW +ZI) }
After I compile the project and download the image into target, debugger puts its pointer at address 0x00000000 which is complete nonsence. Disassemly window looks like this:
***************************************************************************************** 151: 152: /* Get status to se if WIP (write in progress) clear */
0x00000000 5700 LDRSB r0,[r0,r4] 153: sr = Fls_RDSR();
0x00000002 2000 MOVS r0,#0x00
0x00000004 8799 STRH r1,[r3,#0x3C]
0x00000006 0800 LSRS r0,r0,#0
There should be main at address somewhere in 0x0800xxxx. The same happens when I don't use scatter file but set the R/O Base to 0x08001000 in the Linker Tab. If I put in the default value 0x08000000 everything works fine. I use ST-Link.
Does anybody have an idea what's wrong? How could I force the debugger to show propper entry point?
Thank you in advance for any hint.
  • "After I compile the project and download the image into target, debugger puts its pointer at address 0x00000000 which is complete nonsence."
    Not nosence. The processor starts with the reset vector - the processor itself does not know where you decide to load your applications.
    So the simulator would have to do the same thing.
    Unless you have a boot loader that starts with the normal reset vector, your real target will not run your programs.
    For debugging applications in RAM, you can use an ini file that sets the PC to the start address you want, but this is only suitable for debugging. For real programs you need to take care of the real reset address of the processor in your application or in a boot loader.
