Hi there, i've got a project realizing mc8051 on a FPGA board and using mon51 of keil uvision3 for debugging. I got my VHDL code implemented and tested the functionality, the UART interface of the MC is working correctly, memory space is also von neuman wired, but the communication between my MC and the keil uvision is always wrong. I used the baudrate 9600 for the mon51 program. Is there any way to look inside what is going on? I mean is there any way to see if the mon51 on the ROM of my MC is working and is receiving some data from uvision? p.s. i used a new setting for mon51. For example i changed the starting address of xdata and code, excuted the install-batch with proper parameter, and generated a new hex file for mon51 of keil uvision. But the keil uvision always seems to be working with the old mon51 setting. Why?
thanks & regards chris
"realizing mc8051 on a FPGA board and using mon51 of keil uvision3 for debugging"
If you've got an FPGA, why would you not provide JTAG debugging?
Why still using uVision-3 ?
"Is there any way to look inside what is going on?"
A JTAG debugger!
hi andrew, you mean a jtag debugger for fpga or for mc8051? If a jtag for 8051 then should i also design a bootloader for it? I'm currently using spartan 3e evalboard of xilinx. thx
i'm using ipcore from oregano, so there is no jtag interface implemented. What i've currently done is using keil uvision3 to generate a mon51.hex, and initialize this file into my rom to get communication with uvision3 using monitor program. But by far i haven't got any success. What should i do?
Debugging with a monitor is from the days when the dinosaurs roamed the earth. Today JTAG (or similar) is almost standard.
Erik, if you want to show how brilliant you are, go somewhere else. What i need is a solution, not somebody playing teacher's game. I'm sorry for being rude, didn't mean to, though.
As Erik says, JTAG really is de rigueur these days - why would you choose a core without it?
http://www.keil.com/dd/ipcores.asp
Because i don't have any choice, that all i've got. My job is to implement this 8051 ipcore into my fpga board, connect it with keil uvision's monitor program. We don't have jtag debugger.
I trust you have fed-back to the person who did make the choice, and ensured that they are aware of the implications...
"My job is to ... connect it with keil uvision's monitor program"
Are you familiar with doing that on a standard 8051 chip?
If not, that would probably be the place to start. Then you will have a reference point for your FPGA implementation...
Do you mean this:
www.xilinx.com/.../spartan-3e_board_and_kit_documentation.htm
" href= "http://bit.ly/pjmJp6">http://bit.ly/pjmJp6
Yes,exactly.
So have you looked on the Xilinx site for stuff about their JTAG support?
Oregano 8051: www.oregano.at/.../8051.html
"If you have any comments or questions regards our 8051 IP core please feel free to contact us. We also offer - commercial - support for using and/or adapting the 8051 IP core in your industrial FPGA/ASIC designs. Please contact us for more details!"
Have you contacted them?
Yes andrew, a lot of times. But they were apparently not interested in my project, i didn't even get a response.
Does the monitor use 8-bit uart or 9-bit uart?
Please read the manual: http://www.keil.com/support/man/docs/mon51/mon51_config.htm
Thanks, there is one thing i'm not clear. I have my monitor program place at 0x8000h, and xdata from 0x7f00h to 0x7fffh, and user program from 0x0000h to 0x7effh. Do i need to modify the MON_BANK.A51 file?
