ARM7: PROBLEM RELATED TO USB HOST
hi,
Actually i m using lpc2468 controller.i m trying to write data in pen drive using USB through lpc2468.but the problem thet i m facing is that,when i format my pendrive using FAT16 through PC and try to write the data in pendrive through LPC 2468,the controller is not able to write the data.
but if after formatting my pendrive if i create a .txt file in pendrive and delete it immediately and then when i connect the pendrive to controller, the controller is able to write the data.
What can be the problem????
<\b>
