Failed to locate the driver.
I have a ULINK board and have Keil(4.13a) installed..
detailed information is listed below :
IDE-Version:
¦ÌVision V4.13a
Copyright (C) 2010 KEIL(TM) Tools by ARM
Tool Version Numbers:
Toolchain: RealView MDK Professional Version: 4.13a
Toolchain Path: BIN40\
C Compiler: Armcc.Exe V4.1.0.561
Assembler: Armasm.Exe V4.1.0.561
Linker/Locator: ArmLink.Exe V4.1.0.561
Librarian: ArmAr.Exe V4.1.0.561
Hex Converter: FromElf.Exe V4.1.0.561
CPU DLL: SARM.DLL V4.13a
Dialog DLL: DARMP.DLL V1.50
Target DLL: BIN\ULP2ARM.DLL V2.09
Dialog DLL: TARMP.DLL V1.50
Unfortunately , it looks like that the keil doesn't provide proper driver for this ULINK.
Since I have the experience of USB driver on windows XP , I can gather some specific USB information and share them here .
1 . After being plugged , ULINk is reported as "ULink pro".
2 . With the help of USBView , I check ULinks's PID is 2710 while the provided driver inf contains 2728 or 2730 . That's why no driver is selected for installation .
So what version of Keil provide driver for 2710 ??
3 . I tried to revise the inf file by appending one entry :2710 and accordingly the driver can be installed and "Ulink pro" device shows up in Device manager . HOWEVER , the Keil always complains "no Ulink device found". I suppose it is caused by the incorrect version of driver that I just installed by cheating Windows .....
With these information , please help to shed some light ......
Thanks a lot .
Daniel
  • I have solved this problem .
    It is caused by the incorrect driver file. when the new Hardware wizard pops up , I make the path directed to arm\ulink . Actually , the driver in this folder is not suitable.
    The right way is to let the windows automatically search for it.
    I suppose the key point of this issue is ULINK has several versions ....like, Ulink , ulink pro... That's make the thing different and might make newbie dizzy .
    Anyway , hopefully, it is helpful to you ....
