Still confused
I understood why PINSEL0 is used for P0_15 & PINSEL1 is used for P0_16 .
I tend to get confused when i see different codes being used for different Application notes.
PINSEL0 |= 0x00050000; // Select UART1 RXD/TXD
How TXD/RXD is being selected through PINSEL0 inspite it is clear that RXD OF Uart1 can be slected only by PINSEL1 ?
  • Why do you create new threads for the same subject?
    http://www.keil.com/forum/19109/
    Don't you notice the difference between "Start a thread" and "Reply"?
    Next thing.
    You are confused by this line:
    That would set bits affecting P0.8 and P0.9.
    P0.8 have alternatives (P0.8, I2STX_WS, MISO1, MAT2.2)
    P0.9 have alternatives (P0.9, I2STX_SDA, MOSI1 or MAT2.3)
    So the question then is: Where did you see that line? If you want help with a specific line that doesn't make sense, it would definitely help if you posted where you found it. Don't you think so?
    Next thing.
