Does anyone know why this doesn't work:
#define x 5;
if(state == x){... }
Does anyone know why I can't do the above comparison?
Yes, someone do have ideas about your problems.
By the way - is it just your compare that fails? You don't happen to get a compilation error? Have you tried pen and paper and replaced the "x" with "5;"?
I think I wasn't clear. I am getting a compile error. If I replace the x with an actual number, the code compiles correctly.
Are you sure you understand what a define does? Hint: drop the semicolon.
Yes - because it's wrong!
See Andy's Handy Hint for Debugging Preprocessor Problems: www.8052.com/.../29152
Note that this is a general (and quite common) 'C' mistake - nothing specifically to do with Keil or ARM or 8052/8051...
Thanks that definitely solved the issue.
"I think I wasn't clear. I am getting a compile error. If I replace the x with an actual number, the code compiles correctly."
You were plenty clear. And I thought I was plenty clear when I asked you to manually replace "x" with "5;" - does this look like "good" text-book C code?
if(state == 5;){... }
