I have a problem with typedef union as parameter for a function-call.
definition of the typedef
union uParameter { byte bByte; // 8 bit unsigned int16 iInt16; // 16 bit signed int32 iInt32; // 32 bit signed }; typedef union uParameter USR_tu_Para;
prototype of a function that uses this typedef
void SetSomething(USR_tu_Para para);
The question is: how can I call the SetSomething-function with a constant parameter.
SetSomething(100);
This call creates a compiler error: #167: argument of type "int" is incompatible with parameter of type "USR_tu_Para"
I tried to cast the parameter witch (USR_tu_Para) or (USR_tu_Para.iInt16). But the compiler denied everything I tried.
Any ideas?
You could use conversion functions like int2union() and hope that the compiler inlines them...
int2union(); it looks like I do not have too much other possibility except of not using unions or your solution.
"hope the compliler inlines" Hope is the last to die ;-)
