Hi everybody! Good Morning... I am using LPC2368. I have faced a problem with Ethernet connection. i have used easyweb for Ethernet. Can you please tell me how to connect with my computer.? and how can i see the results.? how to send data and receive data .? Plz help me.... or post some link which help me to connect with LPC2368.
Did you switch the power on in your computer?
Does this "easyweb" not have any documentation to help you...?
I have only code for that ,, nothing about documentation... any link about doc??
So where did you get that code?
Did it not occur to you that you would require documentation in order to use it?
Actually when i bought a development board LPC2368. i take this code form there folder... Now if u want plz help me...... kindly ..
Which board, exactly, did you buy?
Have you contacted the supplier for support on this?
"i take this code form there folder"
Did that folder not also have the Documentation with it?
Are there other folders with the Documentation in?
"if u want plz help me"
I don't mind helping you - but I won't do your work for you!
Mr.Andy Neil ! If i have any documentation abt that .. why i gona tease u .. again nd again... i know ur helping men. and also It contains only code no documentation ... thanks ....
So throw it away and find something else that does come with adequate documentation to allow you to use it!
You still haven't said what board it is, so how can anyone help you with anything about its software?!
LPC2368 Development Board See this link.... www.micro4you.com/.../prod_74.html
For specific questions about their software, you should contact them!
www.micro4you.com/.../info_2.html
Note that they have their own forum: http://forum.micro4you.com/
Ok thank you very much for replying ........ and for better guidelines. Thanks
