First of all: I'm using a XE167FM-72 microcontroller. I'm stuck using the va_* family of functions. I've looked into the generated assembler code, it seems that it passes the first parameters directly via registers, and put the rest on the userstack.
Example for a call:
task7_va(3,2,3,4,0,0,0,0); give me
00C0512A E004 MOV R4,#0x00 00C0512C 8840 MOV [-R0],R4 00C0512E E004 MOV R4,#0x00 00C05130 8840 MOV [-R0],R4 00C05132 E004 MOV R4,#0x00 00C05134 8840 MOV [-R0],R4 00C05136 E00C MOV R12,#0x00 00C05138 E04B MOV R11,#0x04 00C0513A E03A MOV R10,#0x03 00C0513C E029 MOV R9,#0x02 00C0513E E038 MOV R8,#0x03 00C05140 DAC0CC4F CALLS task7_va(0xC04FCC)
va_start(vl,count); in task7_va give me
00C0501A E6F41000 MOV R4,#0x0010 00C0501E 0040 ADD R4,R0 00C05020 66F4FF3F AND R4,#0x3FFF 00C05024 F2F504FE MOV R5,DPP3:0x3E04 //comment from me: loads DPP2 (0x380) into R5 00C05028 C4400200 MOV [R0+#0x0002],R4 00C0502C C4500400 MOV [R0+#0x0004],R5
arg = va_arg(vl,int); in task7_va give me
00C05036 E026 MOV R6,#0x02 00C05038 D4500400 MOV R5,[R0+#0x0004] 00C0503C D4400200 MOV R4,[R0+#0x0002] 00C05040 0046 ADD R4,R6 00C05042 C4400200 MOV [R0+#0x0002],R4 00C05046 D4500400 MOV R5,[R0+#0x0004] 00C0504A D4400200 MOV R4,[R0+#0x0002] 00C0504E E026 MOV R6,#0x02 00C05050 2046 SUB R4,R6 00C05052 DC55 EXTP R5,#2 00C05054 A9C4 MOVB RL6,[R4] 00C05056 F4D40100 MOVB RH6,[R4+#0x0001] 00C0505A F046 MOV R4,R6 00C0505C C4400C00 MOV [R0+#0x000C],R4
I don't see where the direct access to the registers r8...r12 are happening. I have problems not getting the correct values, that's why I'm digging into this a bit deeper. I hope that it doesn't make any assumption where the userstack (R0) and the register bank (CP) are (there are of course an legal positions for the microcontroller point of view) - I need to change them via assembler.
Best regards, Michael Fritscher
