va_start/va_arg: how do these work? Have problems with them.
First of all: I'm using a XE167FM-72 microcontroller.
I'm stuck using the va_* family of functions.
I've looked into the generated assembler code, it seems that it passes the first parameters directly via registers, and put the rest on the userstack.
Example for a call:
task7_va(3,2,3,4,0,0,0,0); give me
00C0512A E004      MOV      R4,#0x00
00C0512C 8840      MOV      [-R0],R4
00C0512E E004      MOV      R4,#0x00
00C05130 8840      MOV      [-R0],R4
00C05132 E004      MOV      R4,#0x00
00C05134 8840      MOV      [-R0],R4
00C05136 E00C      MOV      R12,#0x00
00C05138 E04B      MOV      R11,#0x04
00C0513A E03A      MOV      R10,#0x03
00C0513C E029      MOV      R9,#0x02
00C0513E E038      MOV      R8,#0x03
00C05140 DAC0CC4F  CALLS    task7_va(0xC04FCC)
va_start(vl,count); in task7_va give me
00C0501A E6F41000  MOV      R4,#0x0010
00C0501E 0040      ADD      R4,R0
00C05020 66F4FF3F  AND      R4,#0x3FFF
00C05024 F2F504FE  MOV      R5,DPP3:0x3E04 //comment from me: loads DPP2 (0x380) into R5
00C05028 C4400200  MOV      [R0+#0x0002],R4
00C0502C C4500400  MOV      [R0+#0x0004],R5
arg = va_arg(vl,int); in task7_va give me
00C05036 E026      MOV      R6,#0x02
00C05038 D4500400  MOV      R5,[R0+#0x0004]
00C0503C D4400200  MOV      R4,[R0+#0x0002]
00C05040 0046      ADD      R4,R6
00C05042 C4400200  MOV      [R0+#0x0002],R4
00C05046 D4500400  MOV      R5,[R0+#0x0004]
00C0504A D4400200  MOV      R4,[R0+#0x0002]
00C0504E E026      MOV      R6,#0x02
00C05050 2046      SUB      R4,R6
00C05052 DC55      EXTP     R5,#2
00C05054 A9C4      MOVB     RL6,[R4]
00C05056 F4D40100  MOVB     RH6,[R4+#0x0001]
00C0505A F046      MOV      R4,R6
00C0505C C4400C00  MOV      [R0+#0x000C],R4
I don't see where the direct access to the registers r8...r12 are happening.
I have problems not getting the correct values, that's why I'm digging into this a bit deeper.
I hope that it doesn't make any assumption where the userstack (R0) and the register bank (CP) are (there are of course an legal positions for the microcontroller point of view) - I need to change them via assembler.
Best regards,
Michael Fritscher
