Using Cypress FX2 external RAM for code larger than 16k
I've scoured through both this site and at cypress to try and find out how to do this, but nothing seems to work. I have program code which is 27k in size, and the internal memory on the FX2 is only 16k; however, the FX2 allows using up to 64k via an external SRAM.
The difficulty I'm having is that when my program size goes over 16k, the Keil monitor stops responding, and my initial startup code that alights an LED never get exectued.
In the Project->Options->User tab of uVision4, I am running the hex2bix program with the -E argument and a memory size of 32k (my EEPROM is larger than that) to be sure. However, I don't think this program should affect the monitor/debugger's ability to run, nor affect my LED lighting code.
My thought was that the address space used by the Keil monitor (I'm using mon-ext-sio1-c0.hex) was being overwritten, but the Keil website says that the monitor uses this address space:
C:E800h — C:FFFFh Monitor ROM
Which I should be nowhere near, given that I'm only using 27k.
It sure seems like there's an option I'm missing or something, but when I comment my code down to 16k, things work well -- as soon as I cross that threshold though, nothing seems to work at all.
Thanks for any help!
