Hi, The following run perfctly on the Keil...But if downloaded on board it dosen't work...I connected the board with PC and Send Values on UART through Hyperterminal...Is their anything I need to Change?
#include <LPC21xx.H> // LPC21xx definitions #include <stdio.h> char command=0; __irq void Uart_isr(void) { command=U0RBR; VICVectAddr=0; }
void SlowDown (unsigned int delay )// Number of 100us timeouts used for waiting {
unsigned int ii,jj; for(ii=0;ii<=delay;ii++) { for(jj=0;jj<1000;jj++); } }
int main(void) {
PINSEL0 = PINSEL0 | 0x00000005;
U0LCR = 0x83; /* DLAB=1 8 bits, no Parity, 1 Stop bit */ U0DLL = 97; /* 38400 Baud Rate @ 15MHz VPB Clock */ U0DLM = 0x00; U0LCR = 0x03; /* DLAB=0 */ /* transmit enable */ U0IER=0x01; /* disable all interrupts */ VICVectAddr0=(unsigned int)Uart_isr; VICVectCntl0= 0x20|6; VICIntEnable=1<<6;
while(1) { //SlowDown(200); printf("Enter command(x-Request ADC data \nc-Request ADC data at 0.5 Hz \n)::"); //SlowDown(200); U0IER = 0x01;
while(command==0); switch(command) { case 'x': case 'X':
printf("\n Command X\n"); break; case 'c': case 'C': printf("Enter 'T' to terminate the operation:"); while(command=='c' || command=='C') { printf("\n Command C\n"); } break; default: printf("Invalid command detected..."); break;
} command=0; } }
Are you sure this code is working correctly?
Yes: you need to re-post that code - but, this time, following the instructions for posting source code:
www.danlhenry.com/.../keil_code.png
