Whenever I try to send float value on the UART, the code compiles perfectly. But when I try to burn in on my LPC2138, it doesn't burn. Can you help me in solving my problem?
my code is:
printf("%f",AnsAfterNSamples(N)); //where AnsAfterNSamples(N) retruns a float
The error is as follow:
Programming Done. Contents missmatch at: 00001000H (Flash=FFH Required=00H) ! Contents missmatch at: 00001001H (Flash=FFH Required=00H) ! Contents missmatch at: 00001002H (Flash=FFH Required=D4H) ! Contents missmatch at: 00001003H (Flash=FFH Required=E5H) ! Contents missmatch at: 00001004H (Flash=FFH Required=00H) ! . . . . . Contents missmatch at: 0000105EH (Flash=FFH Required=00H) ! Contents missmatch at: 0000105FH (Flash=FFH Required=1AH) ! Contents missmatch at: 00001060H (Flash=FFH Required=01H) ! Contents missmatch at: 00001061H (Flash=FFH Required=00H) ! Contents missmatch at: 00001062H (Flash=FFH Required=17H) ! Contents missmatch at: 00001063H (Flash=FFH Required=E3H) ! Too many errors to display !
