Casting to a union type without using a dummy variable
Hi all,
I am trying to find a way to cast a value to a union type without the use of a dummy variable. My union definition is something like
typedef union _MY_UNION {
    unsigned long u32;
    unsigned int  u16;
    unsigned char u8;
    signed long s32;
    signed int  s16;
    signed char s8;
    float fl;
} my_union;
I have discovered that I can assign a value to the union at initialization using a line like
my_union z = { 0 };
which works fine. It assumes the first union member as the type of the assignment, so ends up doing the same thing as
my_union z;
z.u32 = 0;
except in a much cleaner fashion.
Now for the tricky part -- I have a function that accepts this union type, i.e.
void do_union(my_union u) { ... }
and I would like to be able to call this function without having to pass through a dummy variable first, i.e.
do_union(z);              // works as expected, given the definition of z above
do_union(0);              // C193 incompatible operand
do_union((my_union)0);    // C215 illegal type conversion
do_union((my_union){0});  // C141 syntax error near '{' (as expected; this is initialization syntax)
I get the exact same errors if I use a variable of any member type (including the first) instead of the constant 0. The only way I have been able to get this to work is to use a dummy union variable, i.e.
unsigned long i;
my_union t;
t.u32 = i;
do_union(t);
Is there any way to get around this, and let me call the function directly without the use of a dummy variable?
Regards,
-Scott
