hi where to get help about initialization (*.ini) files? how to start?
What?
you can initialise a .ini file with the command
echo STUPID QUESTION > myinifile.ini
Please read the manual?
http://www.keil.com/support/man/docs/uv4/uv4_debugging.htm
http://www.keil.com/support/man/docs/uv4/uv4_dg_debug.htm
http://www.keil.com/support/man/docs/uv4/uv4_debug_functions.htm
support.microsoft.com/.../289022
i have an example project downloaded from net for lpc3250. in target option under debug tab RAM.ini file is linked. without this file control is not entering to main. In lpc2468 without ini file we can debug/program. but here in lpc3250 some problem is there. this is what my confusion. sample file is
/***RAM.ini***/
FUNC void Setup (void) { // <o> Program Entry Point PC = 0x08000000; } Setup(); // Setup for Running
